How Thick Should My Thinset Be? - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-18-2009, 09:07 PM   #16
yummy mummy's Avatar
Rewards Points: 1,016
ccarlisle;
Actually, I figured it out all by myself. Can you believe that???????
yummy mummy is offline   Reply With Quote
Old 06-18-2009, 09:33 PM   #17
Tileguy
Bud Cline's Avatar
Rewards Points: 558
YM,
Are ya sorry ya asked by now?
Good Lord guys!!!
YM you know where to find me.
Old 06-18-2009, 09:49 PM   #18
I am and thank goodness you're back.
Old 09-26-2009, 11:43 PM   #19
YM, HOPE YOU GOT YOUR ANSWER WHILE DOING IT. Not sure how your thin set came out, but hope it worked for you. I'm about ready to start my thin set, but was wondering if I not go thru this but get the pre-mix motar from HD. I'm be puting it over my sub floor than cbu then motar again for the tile. Im concerns about doing the mix, I can't even get a right pancake mix correctly(too watery and no patient.
Any answers or advices before I start from you or others will be a great helps.(Isn't this what the forum for =to get some advices and tale from other experts.
eyeglass is offline   Reply With Quote
Old 09-27-2009, 09:27 PM   #20
I am no expert by any stretch of the imagination.
I don't know how good pre mixed mortar is, I have never used it.
I used modified thinset Flexbond for my ceramic tiles.
When you mix your mortar you can follow the instructions on the bag. It tells you how much water to add.
When I mixed my thinset, I made sure that when I troweled it on that the ridges stand up and do not fall. After a while you will get the hang of it.
Good luck.
Old 09-28-2009, 12:36 PM   #21
Tileguy
Bud Cline's Avatar
Rewards Points: 558
eyeglass: (snip) "I'm about ready to start my thin set, but was wondering if I not go thru this but get the pre-mix motar from HD. I'm be puting it over my sub floor than cbu then motar again for the tile. Im concerns about doing the mix, I can't even get a right pancake mix correctly(too watery and no patient."
Rediculous!!! Please use "real" thinset. Go read your other thread on the topic, there are plenty of warnings for you there.
XXX
How big of a gap in hardie board can I fill with thinset? Constant Improvement Flooring 8 03-21-2011 06:43 PM
questions about thinset ponch37300 Flooring 16 03-16-2011 11:45 AM
Fortified Thinset poolecw Flooring 4 10-31-2008 07:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 03:51 PM
How thick a layer of thinset ? Piney Flooring 2 11-10-2006 02:32 PM
