How Should I Reinforce This Subfloor? - Tiling, ceramics, marble - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 10:38 PM   #31
Tileguy
JazMan's Avatar
Rewards Points: 422
Hey Bud, with your $$$ and my brains we might be able to do it. So send $$ fast.
Jaz
Old 12-01-2011, 09:26 AM   #32
Rewards Points: 310
Ok thanks a lot for the help guys. I guess the obvious benefit of screws (or even carriage bolts) over nails is that they won't let the two pieces of wood separate over time..? The only concern/question I have then is how many carriage bolts should I use?
NewHomeDIYGuy is offline   Reply With Quote
Old 12-01-2011, 10:17 AM   #33
Tileguy
JazMan's Avatar
Rewards Points: 422
If you sister with 2x8 - 2x6 I would go about every 24".
Jaz
Old 12-02-2011, 10:41 AM   #34
Rewards Points: 310
Ok thanks Jazman.. last question for you guys (for now at least). Construction glue or no glue for sistering the joists?
Old 12-02-2011, 11:07 AM   #35
Tileguy
JazMan's Avatar
Rewards Points: 422
Yes glue the sisters. Construction or wood glue, depends on how fast you can work and which is closer.
Jaz
Old 12-05-2011, 10:01 AM   #36
Rewards Points: 310
Just wanted to poke in and say thanks guys for the help! I ended up using 3" deck screws spaced about every 12" w/ 2 rows on the 2x8 joists, and going in w/ the framing nailer in between the screws. I also used PL premium adhesive and it's very solid. I opted to not use carriage bolts because of the time (and some of the spots are hard to get to). I probably overdid it with the nails and screws, but it's very solid, and a few more screws/nails I figure couldn't hurt. I'll try to post up some pictures later. Thanks!
subfloor izzyk Building & Construction 0 07-15-2011 05:34 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 09:50 PM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 08:06 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
