How To Repair Shower Tile Pulling Away From Wall? - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-11-2013, 04:34 PM   #16
it's hard to tell from the picture, but it doesn't look like there is a liner there. if there is it doesn't go all the way over the curb.
Old 06-11-2013, 06:16 PM   #17
Rewards Points: 682
I'm not sure of the material behind the tile. I think that it is the blueboard that is used in wet areas???
There is a gap between the board areas(you can kind of see in the pictures). I didn't know if that was an issue that needs to filled in prior to putting the tile back on? I do think that the pan is grey. I think that it was a hand constructed liner.
What do you think? Is there more that I need to do pror to putting the tile back on to help prevent this from occuring again? Thanks!!
kennykenny is offline   Reply With Quote
Old 06-11-2013, 09:13 PM   #18
DIY staff
Rewards Points: 7,174
Two questions---
what is the backer made of-??? is it cement ? Cement board? Gypsum?
Is the stuff on the back of the tile a cement based thinset or a soft mastic?
Old 06-11-2013, 09:20 PM   #19
Tileguy
JazMan's Avatar
Rewards Points: 422
What Mike asked...... I was about to ask the same.
You thought the backer was blue-board. If so, that's a big problem. You also need a waterproofing membrane over the correct backer. Backer boards are nailed or screwed in place, that kinda makes holes in the shower pan. That's wrong.
Kenny, you need to tell us what you see, those pics aren't so good.
Jaz
Old 06-12-2013, 03:19 AM   #20
Rewards Points: 4,796
Whatever it is, it looks moldy to me. There is some black residue on the tile. Also the tile doesn't have much adhesive on it.
jeffnc is offline   Reply With Quote
Old 06-12-2013, 08:40 AM   #21
Rewards Points: 254
Duct tape that tile on and sell the house......jk......I think you might be in for a tear out of at least the floor and see what you find.
pwgsx is offline   Reply With Quote
Old 06-12-2013, 09:48 AM   #22
Rewards Points: 682
I don't know if these new pictures help but I have attached some new ones.
Upon a closer look, its not blue board. It feels like cement board< although I am not sure what that feels like. When I put my fingernail into the boar. there is a slight give to the material. It is not gypsum.
I did scrape off a substantial abount of material off the back of the tile. I believe that the material on the back of the tile is thinset.
How to repair shower tile pulling away from wall?-tile1.jpg   How to repair shower tile pulling away from wall?-tile2.jpg   How to repair shower tile pulling away from wall?-tile3.jpg   How to repair shower tile pulling away from wall?-tile4.jpg
Old 06-12-2013, 10:08 AM   #23
Rewards Points: 254
Looks like cement board with Aqua Guard on it- its blue/green BUT looks like whatever the curb is made out of has shifted enough to tear thru the water barrier and water got behind it. Bet the curb is wood or something. Also if that is cement board they should have taped and mudded the seam- that space shouldn't even be there. Hate to say it but you need to tear more into it.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Need help getting rid of dark areas on shower wall tile Rav Tiling, ceramics, marble 2 01-27-2013 09:48 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
Tiling Shower: Decorative tile thicker than Wall tile digexpressions Remodeling 11 06-08-2008 05:49 PM
help- it's more than just a tile fallen off the shower wall! infantrymama General DIY Discussions 7 05-27-2008 10:06 PM
