How To Repair Grout On Shower Tiles? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-21-2013, 12:19 PM   #1
How to repair grout on shower tiles?
My bathroom was remodelled 10 years ago. I noticed ants coming in through cracks in the grout at the ceiling and some other places. I still have the original grout product and the sealer. I would like a blow by blow instruction as to how to repair these cracks so the ants won't be able to sneak in. I live in earthquake So. California.
spaqueen is offline   Reply With Quote
Old 08-21-2013, 05:32 PM   #2
Too Short? Cut it Again!
Obviously you need to address the ant issue. They are being attracted to moisture if coming into the bathroom I suspect. Hopefully you do not have water seeping behind your walls.
Assuming the tiles are intact and still nicely stuck to the tileboard...
You can get a roto tool with a grout bit to carve/route out the old grout or a grinder with a flat blade. Make sure you wear eye protection and a dust mask. The tool gets plugged into a GCFI outlet please since you are around water.
Clean all the grout debris and dust thoroughly.
Regrout.
When the grout has set and cured, apply the sealer per instructions.
If the existing grout is 10 years old, be prepared for the new grout to be slightly different in color. If it was sealed properly, the color difference should not be too bad.
If everything is intact it is not a particularly difficult job. It is a messy one though.
The Following User Says Thank You to user1007 For This Useful Post:
spaqueen (08-22-2013)
Old 08-21-2013, 09:41 PM   #3
DIY staff
Rewards Points: 7,174
Do not use the ancient grout---it is junk after 10 years--Buy some new stuff.
If ants are in the house behind the tile---you have a bigger problem than cracked grout---
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
joecaption (08-22-2013), spaqueen (08-22-2013), user1007 (08-21-2013)
Old 08-22-2013, 04:23 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 346
Absolutely, you have an ant problem not a grout problem.
I'm betting you've got a water leak. Grout does not just crack all by its lonesome in the field of a wall/ceiling or floor. Water has saturated the lumber, it's expanded and it's falling apart.
Tile or no tile, grout or no grout, wet or dry, there should be no ants in your house.
Jaz
The Following 3 Users Say Thank You to JazMan For This Useful Post:
joecaption (08-22-2013), oh'mike (08-23-2013), spaqueen (08-22-2013)
What grout color should I use with my tiles? Pics included amodoko Remodeling 16 05-14-2012 06:48 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Removing grout from top of ceramic tiles markdrum1 Tiling, ceramics, marble 3 09-28-2010 09:38 AM
New shower, cracked grout Fleet_Foxes Tiling, ceramics, marble 10 02-18-2010 07:40 PM
Shower floor grout cracking radnrs Flooring 11 09-14-2008 08:49 PM
