How To Pull Up Tile Over Ditra Underlay - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-26-2010, 01:49 PM   #1
how to pull up tile over ditra underlay
We recently installed slate tile in our kitchen with ditra underneath. Although it looks pretty, it is very impratical and "rough" for a kitchen area. We regret the decision to go with this type and want to tear it out and lay down hardwood floors instead. How hard it is to tear it all out? We have done all the work ourselves so only materials and our time invested. We want to cut our losses on the tile before proceeding with hardwood on the main level of our home. What's the easiest way to do this???
diyjo is offline   Reply With Quote
Old 08-27-2010, 03:13 AM   #2
I don't know the answer to your question, but I have one of my own: when you say the slate is rough, are you talking about the tile surface itself or differences in height between tiles? I ask because I'm considering putting slate in a kitchen myself.
JackG is offline   Reply With Quote
Old 08-28-2010, 11:54 AM   #3
Computer hardware consult
Send a message via AIM to it help Send a message via MSN to it help
my solution
I had the same thing in my house. we installed cermic tiles on our slab in the kitchen. I did all the work my self and w. two hammer i got all the all the old cremic tiles broken out and got down to the slap.
two thing to be careful: 1. Making sure you get all the motor out and the ground is smooth. 2. be careful when you take out the floor because you might damage the slab.
any motor that is left on the floor will make it difficult to install the hardwood floors and will cause the floor to creek.
* make sure the slab is sealed so that it is less likely to let mosture to rise up and damage the floors from underneath.
in the case of ditra, usually its installed on top of a slab with a peice of wood in between the slap and ditra.
its going to be difficult removing it because of the the way its installed but it can still be done.
here is why watch this video: http://www.in.com/videos/watchvideo-...a-8102427.html
it help is offline   Reply With Quote
How to make wall smooth after removing tile? cheapchick Remodeling 20 04-09-2012 02:59 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Toilet Flange Problem - New Tile Floor w/ Ditra qwkslvr Flooring 4 10-14-2009 11:04 PM
Vinyl Tile bailey46 Flooring 6 03-01-2009 04:04 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
