How To Make Up An Inch? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-06-2013, 01:19 PM   #1
How to make up an Inch?
Hi Everyone. I am new here and have read alot of posts regarding tiling and specifically the use of Ditra. I am taking on a project to tile an entryway and living area. the entryway will butt up to an existing tile floor.
I need some guidance on how to make up the inch difference to the top of the existing tile. The existing floor used some type of rock board underneath the tile. I always hear faint cracks in certain area's and feel that at some point the old tile will start to show grout cracks etc. I think Ditra is a better option for what I am doing now
The current subfloor is 3/4 ply. The joists are solid, and I did a defleco calculation of 615. The tile is ceramic. 6 * 40 tile.
How would you guys make up this inch.
What should I allow between the Ply & Ditra, and Ditra & tile?
My thoughts are Dirta xl (5/16) + tile (3/8) = 11/16. Will I make up the remaining 5/16 with thinset? - I think that's alot?
Second thought - Plywood (1/4) + Ditra (1/8) + tile (3/8) = 3/4. Is 1/4 more realistic to make up with thinset ?
Would love to hear how you guys would tackle this
regards
vinnie
vmcmahon is offline   Reply With Quote
Old 11-06-2013, 04:03 PM   #2
Rewards Points: 4,796
What does 6 * 40 tile mean?
3/8" tile is pretty thick tile. Even if it is that thick, 5/16 is probably too much to expect from thinset. Normally I like to see that inch, because for me that would mean 1/2" plywood, making an excellent 1 1/4" subfloor base. Then 1/8" Ditra, 1/8" thinset (spread with 1/4" square trowel), and 1/4" tile.
1/4" is also a lot to make up with thinset. Realize that to get 1/4" of thinset, then theoretically you should be using a 1/2" square trowel. That's a monster trowel size, normally only for the biggest tile.
I would go with either 1/2" plywood and Ditra, or 1/4" plywood with Ditra XL. A 1/4" trowel will give you about 1/8" of thinset.
jeffnc is offline   Reply With Quote
Old 11-06-2013, 05:18 PM   #3
Hi Jeffnc - Thanks for your input
6*40, means the tile is 6" wide by 40" Long. Its the new plank look tile. I verified with the tile store today, it is 3/8 thick.
If I go with 1/2 ply, with 1/8 ditra, and my tile is 3/8 - I will be high - the thickness of the thinset under the ditra and between tile/Ditra
If I go with 1/4 ply and Ditra xl, and tile, and taking into account 1/8 for thinset, I will need to make up 3 /16
How noticeable will the first option (Higher) or second option (Lower) be? I think its too much?
any other ideas?
thanks so much
Old 11-06-2013, 05:50 PM   #4
OK, that occurred to me but 40" tile isn't common, so just checking.
Have you thought about what size trowel you'll be using, or is recommended for that tile? You might want to check out some sources.
http://www.tigermountaintile.com/201...k-tile-floors/
You might be getting into territory where you really want 1 1/4" subfloor thickness, to reduce deflection for those super long tiles.
If 40" is monster long. Your floor better be flat and even then you might want to go with that big 1/2" trowel we talked about. To figure thinset thickness, take half the size for square trowels. e.g. 1/2" x 1/2" x 1/2" trowel gives a 1/4" final thinset depth after the tiles are pressed down.
You might want to start looking at transition strips and go for a 1/4" height difference with the 1/2" ply.
Old 11-06-2013, 08:36 PM   #5
Rewards Points: 13,694
1/4" plywood should never be used as underlayment under tile.
Old 11-06-2013, 08:40 PM   #6
You don't seem to be reading fully.
p.s. you don't have to say "under" twice.
Old 11-07-2013, 10:22 AM   #7
Rewards Points: 91
don't worry I am in the same spot- I have a slab on grade and am trying to make up 1 1/2" overall and am laying the 1" hexogon tile mats. I was advised to do a drypack mortar bed that will make up the distance from slab to where the thinset base should be.....
gwilkrrs is offline   Reply With Quote
Old 11-11-2013, 05:40 PM   #8
Thanks for everyone's replies. I feel more comfortable putting down a layer of ply, and then ditra. Its a high traffic area, with large tile so even if its 1/8th higher than the next room, I think it will be ok . thanks so much
Old 11-11-2013, 08:00 PM   #9
Pro
JetSwet's Avatar
Rewards Points: 502
Originally Posted by jeffnc
You don't seem to be reading fully. p.s. you don't have to say "under" twice.
Jeffnc, Joe is right. 1/4" ply should not be under ditra or backboard. It will pucker and you actually loss deflection.
JetSwet is offline   Reply With Quote
Old 11-11-2013, 08:11 PM   #10
Hi JetSwet........ Thanks for your post..... What do you think would be the best approach to make the inch I need? Should I go with the thicker ditra xl?
Old 11-11-2013, 08:23 PM   #11
What are you talking about? Puckering from the screws? It should be screwed to the floor on a close schedule. Puckering can be a problem if covering with vinyl directly, but Ditra is going on top of this. If puckering becomes a concern, then the 1/4" plywood should be stapled instead of screwed.
As far as "loss deflection" - whatever that means - if you're trying to say you will "lose deflection", you're actually right. Adding a structural element such as plywood will reduce deflection, which is a good thing.
Old 11-11-2013, 08:33 PM   #12
Pro
JetSwet's Avatar
Rewards Points: 502
What are you talking about? Why would it "pucker"? That makes no sense. It should be screwed to the floor properly. Plywood is a laminate product. The laminated sheets are the same thickness and glued the same way in 1/4" plywood as in 1/2" plywood as in 3/4" plywood. There's no reason for anything to "pucker" - unless it gets soaking wet, which plywood is never supposed to do, and even then all plywood would have a problem, not just 1/4" plywood. As far as "loss deflection" - whatever that means - if you're trying to say you will "lose deflection", you're actually right. Adding a structural element such as plywood will reduce deflection, which is a good thing.
1/4" is too thin... minimum is 3/8 or 1/2". When you screw down that thin of plywood you will get duvets so between your screws will pucker up. I meant you will have more deflection with 1/4" because it's too thin.
Old 11-11-2013, 08:39 PM   #13
Pro
JetSwet's Avatar
Rewards Points: 502
Instead of 1/4" ply use 1/4" cement board then your tile or... 1/2" over 3/4" then tile but you will need a very good modified thinset and a. BC sanded plywood. This is entry way hall way not a bathroom. You would have. 1-1/4" totally ply if done correct can work.
Old 11-11-2013, 11:00 PM   #14
Do you know what a duvet is? Use staples if puckering becomes a problem.
Adding more structure is not going to increase deflection in the subfloor. Unless you're trying to say the "bubbles" will cause some kind of micro-deflection, but that's not what's meant by deflection.
Of course cement board or Hardibacker can be used under Ditra, but it's not structural. If you just need more space, then Ditra XL would work fine.
Old 11-12-2013, 12:15 AM   #15
JOATMON
ddawg16's Avatar
Rewards Points: 1,810
How about 1/2" Hardibacker and no Ditra?
Tags
ditra , thickness , tile
Converting HVAC 10 inch duct to 6 inch HVAC duct Poochie64 HVAC 6 06-05-2011 02:20 PM
Can I make my bathroom legal? pgiering Plumbing 2 05-11-2011 03:15 PM
22 inch on center joists! please help martinzz Flooring 3 05-04-2011 08:43 PM
best way to make a small water tank? Red Squirrel Plumbing 22 05-01-2011 06:12 AM
Unlevel rooms - They are off by 1 inch - Need Help (**Pictures**) jamminsport16 Flooring 5 03-19-2011 08:30 PM
