How High Should My Ceramic Tile Moulding Be? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 11:49 AM   #1
How high should my ceramic tile moulding be?
How high should my ceramic tile moulding be? It will go onto drywall with FlexBond Crack Prevention Mortar. I've had advice ranging from 1 1/2 to 2. I am gonna cut the moulding from full tiles 12 x 18 or from leftover tiles that were cut for floor edges. Also is drywall strong enough to hold the ceramic moulding of 18 wide, or should I make them 12 wide? Thank you
DiyCR fan is offline   Reply With Quote
Old 03-22-2013, 03:54 PM   #2
Rewards Points: 13,456
No clue what you mean by tile moulding.
Old 03-22-2013, 05:42 PM   #3
sorry if i didn't use the correct term. I believe it's referred to as floor molding or base molding (after you've laid all the tiles down onto the floor, molding would be put onto the bottom of the walls near the floor, directly above the tiles, all around the room)
Old 03-22-2013, 05:53 PM   #4
And how do you plan on covering up the rough flat top edges?
Far better look to go with real base trim.
A real base would have a rounded edge at the top.
Old 03-22-2013, 08:02 PM   #5
I agree rounded edges look better, but my sister does not mind... plus she doesn't want to pay extra for molding... she'd rather i cut up molding from the full tiles. I'll probably sand the edges.
Old 03-22-2013, 08:17 PM   #6
It can be any height she thinks looks good.
Most bases are around 3-1/4 to 5-1/4 but there's no set rule.
DiyCR fan (03-22-2013)
Old 03-22-2013, 08:41 PM   #7
Sanding tile releases silica dust which is dangerous. Try to find cap molding to put on top of the tile and limit the sanding, or just a plain flat piece of wooden molding. Better to sand the wood than the tile.
Dorado is offline   Reply With Quote
The Following 2 Users Say Thank You to Dorado For This Useful Post:
DiyCR fan (03-22-2013), joecaption (03-22-2013)
Old 03-22-2013, 08:53 PM   #8
Tyvm for that heads up Dorado
Old 03-22-2013, 08:58 PM   #9
If my sister is willing to pay extra for wood base molding, will thinset be appropriate to stick the wood molding to drywall? I noticed an article saying to nail it into drywall, which is fine but one wall in this room has cinder blocks behind the drywall
If yes, should i paint the walls first?
Does thinset stick to latex paint?
*Gonna show this to my sister http://www.homedepot.com/p/Woodgrain...6#.UU0RL1fO3kA
Old 03-22-2013, 10:05 PM   #10
Use steel cut masonry nails (that's what Home Depot calls them) to attach molding to concrete.
The Following User Says Thank You to Dorado For This Useful Post:
DiyCR fan (03-23-2013)
Old 03-22-2013, 10:43 PM   #11
Tileguy
JazMan's Avatar
Rewards Points: 346
Do what you want, but I would not use wood base in a bathroom that has ceramic tiles on the floor. It just cheapens the entire room and may not look so good in a few years.
Anyone notice that molding in the link to the HD site? They call that base molding. Idiots!
Jaz
JazMan is online now   Reply With Quote
The Following User Says Thank You to JazMan For This Useful Post:
Old 03-23-2013, 04:27 PM   #12
Jaz
No, it's in a bedroom. That HD link... please tell me what it is. Can i still use it as base molding?
Old 03-23-2013, 04:54 PM   #13
Tileguy
JazMan's Avatar
Rewards Points: 346
Ceramic base is still best for a bedroom, but wood is ok too.
That molding in the HD link is window and door casing. Base looks more like this and is usually 3" and higher; http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051 There are many varieties though.
Jaz
Old 03-23-2013, 07:08 PM   #14
Rewards Points: 944
I would look for some tile with a 6-10" dimension and rip them in half. You can have a factory edge on the top then. Not a bull-nose, but a factory edge.
If you have a good wet saw or maybe a grinder to dress cuts with, then you could get 3 pieces out of 12 & 13" tile.
You'll want to caulk the joint between the baseboard tile and the floor.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
Old 03-23-2013, 07:45 PM   #15
Jaz
so that mislabeled link by HD... can i still use it as "base molding"? I'm having trouble finding a base molding my sister likes. That has a cheap price & it's real wood
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 11:29 AM
Tile over existing ceramic tile jgb29 Tiling, ceramics, marble 4 03-26-2012 11:50 AM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 07:58 PM
Want to change ceramic tile to granite tile smart2surf Flooring 3 06-24-2009 08:11 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
