How To Get A Start A Straight Line For Tiling - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 05:49 PM   #1
how to get a start a straight line for tiling
How can I get my firt straight line to use for my first row of tile when I have nothing straight in the bathroom?
gale1 is offline   Reply With Quote
Old 02-04-2013, 05:56 PM   #2
DIY staff
Rewards Points: 7,174
Walls or floor?
Typically a chalk line is used to snap a straight line down the center of the room----then a measurement is made of the tile --plus one grout line-(actually two tiles and two grout lines-) and that measurement is used to make a line near the wall---
If the second line is 1/2 of a tile or larger--you are good in that direction---
If it is less than 1/2 of a tile---move the center line over by 1/2 tile and use that line to measure over towards the wall----
Once that line is complete---repeat the process in the other direction---
Old 08-09-2013, 01:41 AM   #3
I have also found that you want to check what the tile configuration will be around the toilet. You don't want to have to cut thin slivers of tile, or a three-quarters inner crescent around the flange. As Mike suggests above, get the two perpendicular lines in the "center" of the bathroom, but check edges and around toilet flange, vanity, any other built-in to make sure you don't have a tiny piece at the edge. Move the "center" point over to increase the small piece or eliminate it completely.
jammy54 is offline   Reply With Quote
Old 08-09-2013, 01:53 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,146
Gale....can you post a pic?
What kind of tile are you using?
Like the guys above said, you don't want to end up having little slivers of tile on the sides.
If your tile is not square, you want to make sure you pick the right 'direction'. If the tiles are rectangular, you want them to go in the long direction.
And if you do have one of those really odd shaped areas, think about turning the tiles 45 deg. While it's a bit more tile cutting....it can solve odd shaped area layouts. If you get our line right...the pieces you cut in half get used on each side...with maybe a little trimming.
ddawg16 is online now   Reply With Quote
Old 08-09-2013, 06:36 AM   #5
DIY staff
February---I bet she's done with this one.
Old 08-09-2013, 10:10 AM   #6
JOATMON
ddawg16's Avatar
Well....if she is anything like us...she is just getting around to doing it....
Man...gotta check those dates..........
The Following 3 Users Say Thank You to ddawg16 For This Useful Post:
gma2rjc (06-22-2014), mnp13 (06-23-2014), oh'mike (08-09-2013)
Old 06-22-2014, 11:13 PM   #7
Rewards Points: 362
That's alright about the date of the original post. I still got some good information from this thread!
gma2rjc is online now   Reply With Quote
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-05-2012 12:07 AM
Sewer main line repair question dgeorge Plumbing 4 08-10-2011 08:21 AM
Perfectly straight line Casey Flooring 13 04-05-2011 11:18 PM
How to apply a straight line on same wall, two colors AxelF Painting 11 04-09-2010 06:32 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
