Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 09-06-2009, 08:15 AM   #1
atm
How to Finish Tile Floor around Drain Hole
I am tiling the basement floor and need some suggestions/help on how I should finish tiling around a drain hole. The tile is around 13" x 13" square and the hole is about 4 inches in diameter.
Do you have any suggestions on how I should finish this or do you know of a better way of finishing the drain - maybe theres a nicer/replacemnt product designed to sit on a tile?
Picture without the drain cover.
Picture with the drain cover.
thank you.
atm is offline   Reply With Quote
Old 09-06-2009, 03:44 PM   #2
Tileguy
Bud Cline's Avatar
So what's the problem? Cut a four inch hole in the tile and your done.
Is the drain totally necessary and how often does it get used and for what.
Old 09-12-2009, 12:38 AM   #3
atm
What tool would best make the 4" circle hole? Should I cut a square then use one of those wired tile saw? Any other ideas?
Yes, I think the drain is required in the basement.
Old 09-12-2009, 11:39 AM   #4
Tileguy
Bud Cline's Avatar
That would be one way to approach the problem. I doubt a wire blade will cut floor tile but it might with the right tile. Maybe a better approach would be to "plunge" a square hole then nibble-away at it with a pair of tile-biters. There is a "parrot bill" biter made for just that purpose.
If you want the benefit of the drain but think you may never have to remove the cover to access the egress you could simply drill a series of holes in the tile but don't apply any adhesive to that area when you install the tile.
Typically either a core-saw or a diamond blade on a four inch grinder is used.
Tile shower with out center drain? jrdamien Plumbing 4 04-17-2009 08:43 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
