How Do You Install A Walk-in Shower In A Basement With Floating Walls? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 05:01 PM   #1
How do you install a walk-in shower in a basement with floating walls?
Hi,
I live in Colorado and have taken on the project of finishing my basement. Due to expansive soils in the area, local code requires installation of floating walls. I would like to install a walk-in shower in the basement bathroom however I'm having a hard time figuring out how to install a shower floor (shower pan) while keeping the concept of a floating wall. I've included some pictures of what I currently have as well as a sketch showing how I would like the shower to be oriented.
Another question, does the drain for the shower have to be centered in the foot print of the shower?
Any suggestion that anyone can provide would be greatly appreciated!
Thanks,
R.R.
How do you install a walk-in shower in a basement with floating walls?-dsc03775-small-.jpg   How do you install a walk-in shower in a basement with floating walls?-dsc03772-small-.jpg   How do you install a walk-in shower in a basement with floating walls?-dsc03771-small-.jpg
ronquillor is offline   Reply With Quote
Old 02-20-2010, 05:57 PM   #2
Originally Posted by ronquillor View Post
Hi,
...I would like to install a walk-in shower in the basement bathroom however I'm having a hard time figuring out how to install a shower floor (shower pan) while keeping the concept of a floating wall.
This link might help:
http://www.asktooltalk.com/questions...ting_walls.php
The idea is to maintain flexibility in the water supply and drain connections so that movement will not result in fractures. Sounds like rubber couplings might be useful here. As to the rest of it, my sense is that you want a solid base for the pan, but one that is not rigidly attached to the walls. A large overlap between base and wall structure should let you accomplish this. YMMV.
Nope. Just trowel the pan to have the drain at the lowest point. Nothing requires it to be anywhere other than that. Good luck!
Mr. Coffee is offline   Reply With Quote
problem with floating walls ron0805 Carpentry 4 10-12-2009 09:40 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Floating Floor vs. Glue down on basement slab KG032973 Flooring 9 02-23-2009 05:14 PM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 02:02 PM
Acrylic shower walls, cement board needed? SDG Plumbing 3 10-01-2008 08:05 AM
