Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 09-06-2009, 08:42 AM   #1
atm
How to cut 16 x 32 Floor Tiles & Trowel size to use
I need to install 16" x 32" porcelain floor tiles that are about 1/4" thick on a basement floor. I am wondering what is the best method to cut these tiles.
I've used a smaller wet tile saw with 4.5" blade to cut smaller tiles but these tiles are thick and are larger than the platform of the wet tile saw. After using the wet tile saw on smaller tiles, it looks like the bigger 16 x 32 tiles will take longer to cut plus it would be unstable to run the large tile on a smaller wet tile saw.
Do you have suggestions on a better/faster way to cut these tiles and still get a clean cut?
Also, what trowel size should I use for these (1/4" or 1/2" square notched trowels)?.
Picture of wet tile saw.
Picture of 16"x32" floor tiles.
Thanks.
atm is offline   Reply With Quote
Old 09-06-2009, 03:41 PM   #2
Tileguy
Need a much much bigger saw that's all. Those tiles you are using are becomming very popular lately. I use a bridge saw and it works great, costs about $1600. You may be able to rent one somewhere.
I can also tell you, you can expect some problems using tiles that big. The substrate must be very very flat.
Some days I aspire to becoming a missing person.
Old 09-06-2009, 10:08 PM   #3
Tileman-Manufacturers rep
YIKES! 16x32" tiles on a basement floor? I hope your floor isn't like most basements. Bud is right, that floor needs to be flat like your kitchen table.
Trowel? Maybe 1/2x1/2 square or U. Might have to go with a 3/4"x3/4 U. What type and brand thin set mortar were you going to use?
Jaz
Tile 4 You Inc. Troy, MI
KERDI Shower Expert...DITRA Installs
Old 09-08-2009, 08:48 PM   #4
yummy mummy's Avatar
I love the tile, but wow really big.
I can see the lipage already................ We are not talking just flat, we are talking REALLY REALLY flat.........
I say go with 1 inch mosaics instead.........
yummy mummy is offline   Reply With Quote
More On This Topic
Hi, My name is Brian Carter on behalf of Expertvillage.com. I have ten years of tile experience. Today I am going to show you what tools you are going to need to cut ceramic tile. First we have a ceramic tile wet saw, this is the large tool here, we are... Read More »
Installing new vinyl flooring is an inexpensive way to improve the look of a room, especially kitchens, bathrooms and laundry rooms. You can save quite a bit of money by installing the vinyl floor yourself. The most difficult step is applying the... Read More »
Hi! this is Brian Carter on behalf of Expertvillage.com. I have 10 years of tile experience. Today I am going to show you just some of the different cuts that we have made already and explain what they’ll be used for. We have got a straight cut... Read More »
Hi, I’m Faith and I’m here at Flat Fork Studio and I’m here to show you some basic tools that you want to have on hand when preparing to do your mosaic tile project. First we have a caulk gun, Liquid Nails adhesive. This is one type of... Read More »
A grouting float is a flat, rectangular piece of metal with a handle on the top that is used to apply grout to a tiled floor. The float is used during one of the final stages of the tiling process and is relatively simple to use. Read More »
[IMG] code is Off
Anyone know where to find a 5/16" x 5/16" V Notched Trowel? fjlcisco21 Flooring 5 08-12-2009 05:58 PM
what size trowel for 4 1/4 x 4 1/4 tiles? Jim W Building & Construction 5 06-21-2009 10:27 PM
Size of whole house fan needed Doug Crf General Discussion 7 06-21-2008 10:47 PM
Trowel notch size 47_47 Flooring 2 12-10-2007 12:46 PM
What size trowel for 20" tiles? kemerick Flooring 9 10-09-2007 10:31 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
