How To Best Arrange This Tile Pattern - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-01-2013, 08:47 PM   #1
How to best arrange this tile pattern
I like this tile, but can't figure out if I best orient each one the same way, or go random. This will be a 5x7 ft floor. Thanks in advance for ideas.
russiand is offline   Reply With Quote
Old 08-01-2013, 09:19 PM   #2
Rewards Points: 6,652
It is your floor, lay it out rough and play with it, until it looks good for you how you want it. Then take a picture, use a sharpie on the back to number where they go, to correspond where they go, when you place them back into the mud.
Helps to have the map taped to the wall with painters tape, so you can move it back as you back out of the room as you finish. I have used this online tool before http://www.ceramic-tile-floor.info/c...gn-your-floor/
Old 08-02-2013, 04:15 AM   #3
An old Tradesmen
Rewards Points: 7,770
Moved to Tiling forum.
Old 08-02-2013, 11:46 AM   #4
Rewards Points: 4,796
If using tiles like that, they almost always look best when oriented the same way. That's how the tile was designed. If going random, you'll probably end up with goofy looking areas somewhere in your floor by the time you're done.
jeffnc is offline   Reply With Quote
Old 08-02-2013, 12:03 PM   #5
Yeah, I was trying to lay it out on the computer. However all the designs I came up with ended up making my head hurt. Thanks for the input. I'll orient them all the same way.
Old 08-09-2013, 09:00 AM   #6
Be careful with "random". Particularly with a larger floor area. You'll tend to use more of one size more than another. It's best to try to pre-plan the pattern if your goal is to use up the same amount of what you've got.
AJPLeBlanc is offline   Reply With Quote
Help! Wall Tile Repair with No Substrate? LauraFixItGirl Kitchen & Bath Remodeling 15 06-06-2013 11:28 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
