Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 05-21-2010, 09:41 AM   #1
How to apply grout sealer on vertical walls?
What is the best, clean way to apply a grout sealer on vertical walls surrounding a bath tub?
Using spray, using a brash or using some other way.
Thanks a lot.
sukhenkoi is offline   Reply With Quote
Old 05-21-2010, 06:27 PM   #2
Do not use aerosol spray. They cause cancer and you do not want to breath in grout sealer mist. Use a brush type applicator and start from the top and work your way down. Do a couple coats right in a row because the sealer will run down the vertical tiles.
Last edited by Scuba_Dave; 05-21-2010 at 07:08 PM. Reason: removed advertising pic
natcotroy is offline   Reply With Quote
Old 05-21-2010, 06:38 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
The spray is not going to cause cancer.
gregzoll is online now   Reply With Quote
Old 05-21-2010, 07:49 PM   #4
Military Mom of 4
Snav's Avatar
Anything can cause cancer.
So - I've found that those bottles with a roll-on sponge top work great. You fill the bottle and when you put pressure on the tip it releases it onto the roller - roll roll roll - tada.
It's great.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Which sealer to use that will slightly darken grout? HenryG Tiling, ceramics, marble 5 02-28-2010 09:41 PM
sealing tile grout questions 4just1don Remodeling 5 06-27-2008 06:37 PM
Grout application...Need an alternative method Termite Flooring 16 06-24-2008 06:39 PM
Retexturing / Priming walls... scheenstra Painting 3 01-28-2008 08:29 PM
