Honed Marble Tile Flooring - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-12-2012, 08:55 PM   #1
Rewards Points: 12
Honed marble tile flooring
Hello all,
I am installing a basket weave honed marble in my entrance way. I have several questions I hope you can help me with.
- what type or brand name of thinnest should I use?
- what thickness notch should I use, 3/16?
- it is a high traffic area. What type of sealer (brand name) should I use? And should I seal before grout? I also saw a product called "easy grout" they say it goes on honed marble before grouting. Has anyone used this? Is it good idea?
Thank you in advance for your help.
dincanta is offline   Reply With Quote
Old 03-13-2012, 08:39 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 340
Dincanta,
You haven't supplied enough info to give a good answer.
Most "basket weave" patterns I've seen are mosaics. We have no idea what you've got there. We don't know their size or thickness. We don't know what the subfloor is made of or whether below, on or above grade.
We don't know what brands or setting products you can get near you. You don't say where you are. You could be in Outer Mongolian for all we know.
How about you take 10 min. and start with a detailed question for us?
Jaz
Old 03-14-2012, 11:30 AM   #3
Hello JazMaN,
Sorry I did not provide enough information. Ill try again.
I am laying a honed marble basket weave 1"x2" patterned tile, surrounded by a boarded of 12"x12", to create a "rug" effect. The tiles are all Venato Carrara Marble, Thickness 3/8". The exact tiles can be found here: http://www.thebuilderdepot.com/carra...ve-mosaic.html
I am placing these over the Durock Tile Membrane system, which I will install over existing tile. The existing tile and sub flooring layers are rock solid, in excellant condition, just outdated styling.
I am in NYC, between my location and the internet, I believe I have access to most products available. The problem comes with making the selection.
Between the big box stores and the local tile stores I get a different answer from each person I ask. The information I would love your advice on, as well as any other knowledge you would not mind sharing, is:
- Type of thinset? and how thick?
- I have been doing research and from what I have read and seen on youtube, am thinking of using the DuPont StoneTech system. I was thinking of their pre-grout, then their Enhancer, followed by their Heavy Duty Sealer. These are all water based products. Your thoughts?
Thanks again. Please let me know if you need more information.
David51st is offline   Reply With Quote
Old 03-14-2012, 09:15 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 340
Are you saying the old floor is ceramic set in a thick mortar base? What is the structure, the framing like? If the floor in in good shape, do you really need the membrane? Might be good to use it, but is there a reason?
I thought that was the pattern you were using, normally the 12x12" would change my answer, but if it's a mudded floor in great shape, I think you should be fine.
The thin set to use is a premium white modified. There are many brands. expect to spend $25-30 and up. A 1/4x1/4x1/4" trowel at a low angle is the right weapon.
Dupont sealers are very good. Pick the finish you want and follow their specs. Not sure if you need to use a sealer after using their enhancer, maybe? Do you know the difference between the enhancer and a sealer?
Jaz
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 01:04 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Marble Tile Glazing Problem dmiller21283 Tiling, ceramics, marble 1 05-27-2011 09:41 AM
Old flooring / installing new vinyl tile gwelton Flooring 2 06-24-2009 03:10 AM
marble tile in bathroom floor Arianeg Flooring 1 03-18-2008 03:07 PM
