Holes Into Tile Don't Match Shower Head! - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 06:33 PM   #1
Holes into tile don't match shower head!
We're installing a shower head base that requires four anchor holes. Mistakenly our "guide" didn't account for an off center pipe. Now our holes are just slightly off and don't match the anchor. In order to use the shower head we'll need to "move" the holes somehow. What are our options? Is it possible to fill and redrill? Is the best option to replace the tile and start over? But the dry wall below has already been drilled. Regardless the holes are going to need to be filled somehow even to use the old shower head to prevent moisture in the wall... I'm a bit thinking out loud here but any recommendations would be very helpful!
Oops1 is offline   Reply With Quote
Old 04-02-2011, 06:37 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
We have some great tile guys here that will be happy to help you, I'm sure, but a photo or two will help.
My shower head leaks when tub faucet is running? Walter Sobchak Plumbing 4 05-24-2010 08:13 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 05:58 AM
Stuck shower head stealthxcat Plumbing 1 05-08-2007 09:19 PM
