Help! Can I Use Thinset Over Wood (plywood) To Adhere Tiles? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-15-2012, 08:37 PM   #1
Rewards Points: 372
Help! Can I use thinset over wood (plywood) to adhere tiles?
Hi all - I've got a small kitchen project and have decided to put in backsplash tile. I'm replacing an old steel backsplash and I've found that a portion of the existing backsplash is attached to unfinished plywood (part of the surrounding cabinets). The wood is clean and relatively smooth, and I've sanded it with 100 grit to get a good surface for adhesion.
What should I use to put the tiles up? The only instructions I've seen on my thinset bucket refers to wallboard, greenboard and cement board. How about bare plywood?
Help!
imautoparts is offline   Reply With Quote
Old 12-15-2012, 10:53 PM   #2
Rewards Points: 744
modified thinset or mastic will be fine.
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
oh'mike (12-16-2012)
Old 12-16-2012, 06:11 AM   #3
DIY staff
Rewards Points: 7,174
Modified thinset is used over plywood frequently---
Tiles that look like wood Tile guy Kevin Tiling, ceramics, marble 17 09-15-2016 01:27 PM
Replacing 2 ceramic tiles over Ditra RichardZ Flooring 33 01-17-2013 12:22 PM
Can I Paint a Plywood Subfloor? LMS1213 Flooring 31 05-06-2012 09:33 AM
How to adhere tile as decoration to wood bureau drawers? roccart Tiling, ceramics, marble 6 01-28-2010 01:58 PM
Stucco over my cedar wood paneling vs stucco over newly installed plywood beesan Building & Construction 5 12-21-2009 12:24 PM
