Heated Flooring Under Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-22-2010, 01:28 PM   #1
Rewards Points: 154
Heated flooring under tile
We are doing a small bathroom, and heard about this tape or something that goes under the tile and heats it. Does this put additional heat into the room if its a small bath? or does this product only heat your feet?
turbomangt is offline   Reply With Quote
Old 10-23-2010, 10:13 AM   #2
Most of the floor heating systems similar to the one you describe that I've seen (never installed one) only warm the floor, not the room.
littlecleo is offline   Reply With Quote
Old 10-23-2010, 12:03 PM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
It mainly heats the floor tile but some heat will radiate off the floor and into the room. It may provide an additional 1 or 2 degrees at the most.
poppameth is offline   Reply With Quote
Old 10-23-2010, 01:46 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Those type of floor heat systems always require supplemental heat for heating the room. Typically they will heat the floor (only) to about 84 degrees Fahrenheit tops.
XXX
Old 10-23-2010, 03:28 PM   #5
Rewards Points: 154
I kick my self every time I think about when we installed our new cement drive, we could have put that system in, I wish we did it, it would have ended my snow shoveling days.
Old 10-23-2010, 05:20 PM   #6
I know it's too late now, but there are electric heating cables made just for that purpose.
Polywanna is offline   Reply With Quote
Old 10-23-2010, 06:04 PM   #7
The correct system spaced correctly will heat the room
Our bathroom does not have any heat except for the electric radiant floor heat
I bought the wire that you install....not the mats
The mats are usually not spaced close enough for heating
If I close the door & turn it up it will heat the room
It puts out ~15w per sq ft
Old 10-23-2010, 07:29 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well you might know it!!!!
OK Dave if you say so but none of the manufacturers of those type systems make that claim that I am aware of, in fact most of them disclaim the idea. So...Buyer Be Ware.
XXX
Old 10-23-2010, 09:43 PM   #9
When my son was younger we would turn it up to 78 before giving him a bath
Shut the door to let the room warm up
I'm not sure if all companies have changed over...
But this one offers a choice of a floor sensor or it will use the sensor in the thermostat on the wall
Just not the pre-made mat systems
....and probably not all systems out there
How does Electric Radiant Floor Heating Work? The heating wires are specially engineered and designed so they provide heat via the specific wire’s electrical resistance. Special insulation is used to provide protection and durability to the heating wires. When the thermostat is turned on (or the timer is activated) electricity is sent to the floor heating system, the wires heat up, and in turn heats up the floor. This heat then radiates from the ground up throughout the room, heating objects and people within the heated area.
Old 10-25-2010, 10:57 AM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
In my experience with using both systems:
All makers of this type of electric "resistance heating" product offer a floor sensor to be used in conjunction with the thermostat. They also offer two choices in thermostats. The higher priced thermostat item is programmable so as to be able to tell the system when to turn itself on and off automatically. The looping-wire is basically the same in either of the two products. With one, the installer loops and spaces the wires with three to four inches of separation and with the other comes wires already looped (woven/spaced) into a mat. They are the same thing.
XXX
Old 10-25-2010, 11:00 AM   #11
Rewards Points: 154
Do you guys have a link for this product? or name?
Old 10-25-2010, 12:05 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Seach: Floor Heating Systems and you will turn up a lot of names.
I use Suntouch from Watts Radiant. There are several others.
XXX
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Tile flooring over heating element Woodchucker Flooring 4 01-21-2009 12:14 PM
confusion over thinsets for installing Ditra over heated flooring fhknox Flooring 12 01-19-2009 07:21 PM
adhesive for tile flooring? AndrewH Flooring 13 11-26-2007 08:58 AM
Bathroom flooring (tile?) Nhrafan Flooring 30 06-11-2007 12:44 PM
