Hardiboard On OSB - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-03-2012, 11:40 AM   #1
Rewards Points: 27
Hardiboard on OSB
I'm installing Hardiboard on the original OSB 5/8" ply that the house was decked with (took up old 1/4" ply that was down because there was some water damage by tub.
What thinset is safe to use under Hardiboard on the OSB substrate?
Based on the pictures of previous water damage, should I cut this section of OSB out and replace it or just put the Hardiboard over it since it is dried out now?
Hardiboard on OSB-image-2288802714.jpg   Hardiboard on OSB-image-4199991400.jpg   Hardiboard on OSB-image-2892554217.jpg
RomanDesign is offline   Reply With Quote
Old 07-03-2012, 01:54 PM   #2
Rewards Points: 12,858
I would cut it all out and replace with Advantec subflooring, there was also suppost to be a layer of at least 3/8, but 1/2" would be better underlayment rated plywood down before the tile board to add strength to the floor.
Old 07-03-2012, 02:05 PM   #3
Rewards Points: 27
Originally Posted by joecaption
I would cut it all out and replace with Advantec subflooring.
Cut out all the OSB or cut out all of the damaged area?
Old 07-03-2012, 02:16 PM   #4
DIY staff
Rewards Points: 7,174
You have a lot of damaged goods there---I believe you will be better if pulling out all the old and replacing with 3/4" AB exposure one plywood--then set your 1/4" Durrock or wonder board on top--Set in thinset and nailed or screwed.
You could leave the good and replace only the bad--then add a layer of 1/2" AB ply and your backer--you must decide which is easier and offers the best height for the finished floor.
JetSwet (07-03-2012)
Old 07-03-2012, 06:49 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
Take all bad osb out and inspect the joists as well make shore there not looking like the OSB does in the pictures.
JetSwet is offline   Reply With Quote
Concrete on hardiboard Gmyers1 Concrete, Stone & Masonry 5 03-24-2012 12:09 PM
6" wall cap under or over the hardiboard planks? robismyname Building & Construction 1 10-03-2010 10:37 PM
Replacement Facia - Use hardiboard or?? smoochas Roofing/Siding 9 08-01-2010 08:26 PM
Hardiboard or Durock tuchodi Drywall & Plaster 2 07-06-2010 10:16 PM
Cutting hardiboard siding mcwilson Carpentry 4 11-18-2006 11:33 PM
