Hardibacker Support For Granite Tiles. - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 07:32 PM   #16
Tileguy
JazMan's Avatar
Rewards Points: 388
Jim,
OK, you're located near the left coast where that kind of construction is common. Unfortunately there is no approved method for tiling over a floor that has framing wider than 24" oc. However we know it works as many thousands of floor are tiled successfully every year out there.
I've even heard of success with 48-50" o.c. where yours is 32". So, lets assume the framing is good enough. Now let's talk subfloor sheets. You have a single 1 1/8"?
Jaz
Old 04-19-2013, 07:47 PM   #17
I also did a little digging to find there is thinset underneath the Hardiebacker. Most of the backer board is secured with staples with some scattered screws that project slightly.
As near as I can tell the backer board is pretty secure with the exception of having no fiberglass tape at the joints. Even given that there is nothing to suggest why virtually all of the thinset had adhesion problems on both the tile and the backer board.
Jim
modela1 is offline   Reply With Quote
Replacing broken brick tiles...newbie here jmiza Remodeling 3 01-25-2013 04:48 PM
Replacing 2 ceramic tiles over Ditra RichardZ Flooring 33 01-17-2013 12:22 PM
loose tiles in bathroom exodus125 Tiling, ceramics, marble 1 05-10-2010 07:43 PM
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 08:41 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 03:07 PM
