Hardibacker Board Vs Cement Durock Board - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 12:37 PM   #1
Rewards Points: 103
Hardibacker board vs Cement Durock board
Hello,
Last year I remodeled my son's bathroom and used cement durock boards for walls and floors for tiling. This year I am planning to remodel my bathroom. I am going to put new walls with tiles around tub and shower and new tiled floor. I went to HomeDepot and salesman recommended me to use hardibacker boards instead of durock cement boards because it is easy to cut them. However, I am not sure about Hardibacker boards reliability in wet areas.
Any opinion or suggestion please?
Thank you.
sukhenkoi is offline   Reply With Quote
Old 02-17-2011, 01:05 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 346
Hardie works pretty much as advertised. I'd recommend it too if I was selling it. It's 90% cement. Other concrete backers work fine too. Some are a little heavier, if that matters to you. Remember Hardie 1/2" is not 1/2" thick, (might make a difference), and I do not recommend it be submerged in water. You weren't clear since you said tub & shower. Is it two areas, or a tub that can be used to take a shower?
It's perfectly fine for a tub surround, OK for stall showers if you know the right way.
You can apply a surface waterproofing on any backer. It's the best way to waterproof walls anyway. What method of waterproofing were you gona use?
Jaz
Old 02-18-2011, 07:57 AM   #3
Rewards Points: 103
Thanks a lot for your opinion.
In my previous bathroom remodeling project I just attached cement durock boards to studs and then put tiles on them. I did not use any method of waterproofing because I was told that it was not necessary for shower and tub surrounding walls. I am planning to use the same approach again. However, salesman in HomeDepot recommended me to use Hardibacker boards instead of Cement Durock boards as it is easier to cut and install them.
Old 02-18-2011, 08:40 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 346
Well, Salesman....at HD? Do you think he knows much more than the very basics? If so, congrats, you've found the one. Did he recommend an adhesive? He didn't mention waterproofing or vapor barrier? Would you like to do the job right this time?
Hardie is just another brand of CBU, there are many.
Great, did he explain how to cut it?
Jaz
Old 02-19-2011, 12:09 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There is nothing wrong with Hardibacker, it's a good product. It isn't as messy as the old-fashion cement boards when you cut it. It also isn't as easy to cut as they make it out to be but you can score and break it sorta like drywall.
It does require either a moisture barrier on the studs behind the board or eliminate the moisture barrier and apply a liquid membrane waterproofing to the surface of the board. The latter is the better.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Subcooled (02-24-2011)
Old 02-19-2011, 12:16 PM   #6
Send a message via AIM to stiksandstones Send a message via Skype™ to stiksandstones
Is there any harm in going STUDS | MOISTURE BARRIER | HARDIEBACKER | LIQUID WATERPROOF | THINSET | TILE ?
(meaning, is it ok to do both moisture barrier AND liquid waterproof?)
stiksandstones is offline   Reply With Quote
Old 02-19-2011, 12:19 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No!
One or the other but not both. If you do both you will trap moisture inside of the wall. Use one method or the other.
XXX
Old 02-19-2011, 12:24 PM   #8
No!
got it, thanks
Old 02-19-2011, 12:53 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 346
Back to how to score-cut Hardie. You score - score - score, then snap up towards the score, not down like you'd cut drywall.
Jaz
Old 03-03-2011, 08:01 AM   #10
Rewards Points: 103
I just finished demolishing a shower cabin in my 25 years old master bathroom. Drywalls were attached directly to studs and tiles through thinset to drywalls. No MOISTURE BARRIER, no LIQUID WATERPROOF. Everything was in an excellent condition. No water damage at all. So, why it is necessary to apply liquid waterproof or moisture barrier?
Old 03-03-2011, 08:02 AM   #11
Rewards Points: 103
Why do I need liquid waterproof or moisture barrier?
I just finished demolishing a shower cabin in my 25 years old master bathroom. Drywalls were attached directly to studs and tiles through thinset to drywalls. No MOISTURE BARRIER, no LIQUID WATERPROOF. Everything was in an excellent condition. No water damage at all. So, why it is necessary to apply liquid waterproof or to user moisture barrier?
Thanks.
Old 03-03-2011, 08:04 AM   #12
Rewards Points: 103
No!
Old 03-03-2011, 08:30 AM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
This is nuts!!
I'm outa here.
XXX
Old 03-03-2011, 08:37 AM   #14
Hey Guys,
I thought that these links might be of some help. One is a video on to install Hardi-board and the other is a written step-by-step.
http://webapps.easy2.com/cm/flash_ex...ge_id=35737765
http://www.jameshardie.com/homeowner...rterInch.shtml
When I first used Hardi-Board I went over their web site for recommendations and instructions. I like to follow the manufactures guidelines exactly. Jazman is less likely to steer you wrong though, I've read a lot of his posts and he probably knows better than anyone. Hope this helps.-Gregg
gotogregg is offline   Reply With Quote
The Following User Says Thank You to gotogregg For This Useful Post:
sukhenkoi (03-04-2011)
Old 03-05-2012, 02:53 PM   #15
Jaz
JazMan - I just stumbled across this discussion on Hardiebacker. I have no tile/stone experience, but like to try many things DIY. I am working on a stone wall project, using hardibacker over sheetrock, screwed through to the studs. No tub or shower, only a single vanity sink in a hallway bath. I am just curious why you snap upwards, that seems counter intuitive. My hunch is going down causes tear-out on the backside of the hardie - is this correct?
Thanks for your time.
ChrisWhitley is offline   Reply With Quote
Sawzall with Remgrit blade for cutting cement board Proby Carpentry 7 08-08-2010 04:47 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
Bathroom cement board dah General DIY Discussions 2 07-11-2006 06:25 PM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 08:32 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
