Hardibacker Board - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-29-2010, 07:09 PM   #1
Hardibacker board
Is there a right side to the board? Which side to score? How to cut out for electrical boxes?
Meg Causey is offline   Reply With Quote
Old 05-29-2010, 07:39 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Hardi 1/4" has an obvious right side to be placed outward because of the grid impression.
Hard 500 1/2" has one side slightly smoother than the other but it really doesn't matter which side is placed outward on either board.
Also doesn't matter which side you score, they are both a challenge.
Cutting-out for boxes can also be annoying. I use a diamond blade on a grinder to cut out holes but there is a lot of dust and the dust can be harmful to your health. Always use proper safety equipment when cutting Hardibacker.
XXX
Old 12-10-2010, 11:34 PM   #3
HAM_DIYer's Avatar
I know this reply is a bit late...sorry.
I just installed almost 30 sheets of hardibacker. I found that for the straight cuts a straight edge and utility knife worked great. Score the backer several times then use pressure to simply break the backer. (Think how you would cut sheetrock - same process)
For areas that need 2 cuts I found that my handsaw worked very well.
I was using a diamond blade in my table saw but hardiboard doesn't recommend any power tools when cutting it.
As for the side up? The 1/4" backer has a grid with circle dimples on an 8" grid. Put this side up.
HAM_DIYer is offline   Reply With Quote
Old 12-11-2010, 10:07 AM   #4
Tileguy
JazMan's Avatar
Rewards Points: 240
Yes, it's a little too late for Meg, but it's an on going problem for people installing Hardie, and most do it wrong.
You need to score but you must snap the board the opposite of drywall.....up, not down.
If it's a small job, you can use a laminate cutter. Large jobs I use a side grinder, outside, with a fan blowing the dust away. No need to cut all the way through for straight cuts. Outlet boxes or holes, drill a hole, use saber saw.
Jaz
JazMan is online now   Reply With Quote
installing backer board over particle board bob mac Flooring 6 07-16-2013 04:15 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 10:41 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 11:03 AM
oak floor install on hardibacker board? cowgirltuf Flooring 5 12-01-2008 02:49 PM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 09:32 PM
