Hardibacker - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-29-2012, 08:43 PM   #1
Hardibacker
Hi,
I have a 2 part question.
1. Can I Use a liquid leveler over installed hardibacker?
2. When installing the 1/4" hardibacker over 1" plywood subfloor in my bathroom the green hardibacker screws did not end up flush with the cement board. What can I do in this situation? I have read other forums and they suggested that you can hammer them in the rest of the way but I wanted to know what you guys thought would be best. I should also mention that I have used different types of drills and nothing will get the screws flush. Also most of the heads of the screws are now stripped and anyway that I try (reverse or forward) it will not move. I have since transferred over to galvanized roofing nails (much easier by the way) but I don't know what to do about the protruding screws. Since the hardibacker was set with thin set could I remove the screws (if possible) after this has dried and replace them with the nails?
Sorry for the long post but I have been at this for awhile now and I am at my wits end. Thanks for any help.
Adam
adam.r is offline   Reply With Quote
Old 08-29-2012, 09:50 PM   #2
Rewards Points: 13,468
You should be using 1/4 backer board not 1/2" what did you use?
You not trying to hit the joist are you?
Use an impact driver not a drill.
Sometimes I predrill with a masonry bit and counter sink before drill, works a whole lot better.
Old 08-29-2012, 10:51 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 346
Hi Adam & Joe,
Liquid leveler, which one?
Many people have trouble with those screws and Hardie backer. When I was forced to use those silly screws I'd drive them, then reverse the drill, then again and drive it home. However..... it's a PITA. Better off using roofing nails as you know. So, go ahead and drive more nails and grind the screw heads off.
Joe asked;
Looks to me Adam is using 1/4".
Jaz
Old 08-29-2012, 10:55 PM   #4
Opps missed that, thanks Jazz.
Old 08-30-2012, 05:29 AM   #5
Hi jaz and joe,
Thanks for your replies. As for the leveler I am using just a premade one called tec? It is a patch/leveler from lowes. I didn't notice before but there seems to be a hump in the middle of the room that gets increasingly worse and dips off to one side I would say maybe 1/8" + at its worst. Also what type of grinding grit should I use to get those down without also getting into the cement board? Once again thanks for your help.
Adam
Old 09-01-2012, 04:04 PM   #6
Additional question about the screws. Instead of grinding them down, I was able to buy a bit that will get the screws out of the board. If I am able to get them out could I just replace them with nails or will taking the screws out mess with the stability of the backer board since the thin set has already hardened?
Thanks,
Adam
Hardibacker Cement Board Thickness Issue With Drywall JasonCA Remodeling 4 02-24-2013 01:00 AM
Screwing down hardibacker and leveling floor adam.r Tiling, ceramics, marble 5 08-20-2012 06:15 PM
How to fill a gap between Hardibacker and drywall seam Starrgazer Remodeling 1 07-17-2012 11:39 PM
Hardibacker and groutable vinyl Wayne Perry Flooring 4 05-11-2011 07:19 PM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 08:56 AM
