Grouting In Tight Spaces...tips Needed - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 08:37 AM   #1
Ironlight's Avatar
Grouting in tight spaces...tips needed
I'm getting close to being ready to grout the mini glass subway tiles that are going up as a backsplash in our kitchen. However, there are four windows that run along the counter, and I don't think my float will even fit under there at all. I'm looking for tips how to do a good job under there and get a nice result.
I'm hoping I can get specific tips from pros or those who have successfully dealt with a similar situation.
Forgive the crappy photo from my phone. Make the tiling job look very bizarre but that is just how the flash illuminated the glass tiles.
Ironlight is offline   Reply With Quote
Old 01-13-2012, 09:03 AM   #2
A Little Of Everything
Rewards Points: 1,364
I have, on occasion, used a small plastic putty knife, and even ended up smearing in some grout with my fingers. Pretty messy, but it got the job done.
Nice picture, by the way. That's going to be really beautiful when you're done!
DrHicks is offline   Reply With Quote
Old 01-13-2012, 09:31 AM   #3
firehawkmph's Avatar
Rewards Points: 1,922
Get yourself a skinny float. I have one that's only 2" wide. Fits into most tight spaces. The other thing you can do is get a grout bag like a cake decorator bag. Unsanded grout goes through well. Sanded is a bit tougher.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 01-13-2012, 09:32 AM   #4
Mike Hawkins
THAT is a major understatement!
Old 01-13-2012, 10:22 AM   #5
Ironlight's Avatar
That sounds like a plan. I have some areas above and below the receptacles which are one tile high. I could cut a plastic putty knife to fit perfectly. Thanks!
Clearly I was assuming this a bit more complicated than it actually is. It's unsanded grout, so it's not going to be a huge ordeal to pack the joints anyway.
Old 01-13-2012, 11:00 AM   #6
Dr,
you're making me laugh. That is funny. I guess I should have said that for the sanded grout, you definitely have to use a canvas bag meant for that purpose, along with mixing the grout just a tad looser than normal. I have used one of my wife's small cake decorating bags with a 3/16" tip for unsanded grout. Most of the time I use traditional floats. I think one of the few times I used a bag to grout was with some tile in a kitchen backsplash that had a 1/2" deep v-shaped bevel with just an 1/8" size joint at the bottom of the bevel. Worked good for that, but still is a pain.
Mike Hawkins
Old 01-13-2012, 01:56 PM   #7
Dr,
Mike Hawkins
Yeah, the cake-decorator type bag certainly has its role. But I don't think it's a very broad role.
I'd love to see a tool that is essentially a caulk tube that you could fill with grout, plug the back end, and use it with a caulk gun. Again, limited need for it, but it could be very helpful!
Old 01-13-2012, 03:22 PM   #8
DeeKayVB's Avatar
Looks great what you have so far. I did my bathroom last week and used my fingers bcos I couldn't find my tool
DeeKayVB is offline   Reply With Quote
Replacing door tips needed dzobrist Carpentry 14 12-29-2011 04:52 PM
Tips needed to cut stud close to wall montpsycho Carpentry 14 01-11-2011 08:03 PM
Tips Needed: Exterior Door with Alarm Sensor ConstantChange Carpentry 2 09-06-2010 09:40 PM
Extreme novice warning: Plaster tips needed. Poser Drywall & Plaster 9 03-19-2010 02:12 PM
Knock down application tips needed gmhut Painting 1 07-31-2008 09:30 PM
