Grouting Question # 1,000 - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 03:06 PM   #1
Grouting question # 1,000
This seems to have been gone over a dozen times but I'm not getting a home run of an answer when I do search.
I'm installing a kitchen backsplash within 1 week, the tiles we bought are 1/2 " squares held together via 12"X12" mesh backing. The squares are all in the brown familiy with some copper colors mixed in. The tiles we will mount behind the range are all copper color.
My question is what color thin set do we use (it may not matter) and what type of grout if there is more then one.
It was mentioned to me that we should apply the tile with a kind of glue (maybe liquid nails type of stuff).
Ideas, hints, sugestions?
08087 is offline   Reply With Quote
Old 03-30-2011, 06:00 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
DO NOT use Liquid Nails or any other construction adhesive.
DO USE modified thinset mortar. It comes in gray and white but the color won't matter.
The grout in this case should be Portland cement grout - unsanded.
The trowel is also important. Use a small notch around 1/8" X 1/8" square or a 3/16" "V" maybe. You can find the 1/8" trowel in the wood flooring department of any home center, you won't likely find it in the tile section.
XXX
Old 03-30-2011, 06:01 PM   #3
Thank you, thank you, thiank you!
Old 03-30-2011, 06:06 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
welcome, welcome, welcome!
XXX
Old 03-30-2011, 07:33 PM   #5
Rewards Points: 150
The color of the thinset may matter if you haven't done this before. If the thinset seeps up too high in any spots between the tiles, it will show around the grout unless you dig the thinset out down low. Best to get grout and thinset the same color, if possible. Ask me how I know.
NancyNGA is offline   Reply With Quote
Old 03-30-2011, 07:42 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If the thinset is going to purge between the tiles it doesn't matter whether the thinset is gray or white, grouts don't usually match either. Besides who ever heard of choosing either gray or white grout because someone was uncontrollably sloppy with thinset.
Purging is easy enough to avoid from the git-go, just don't let it happen. Controlling the application of the thinset is easy using the right trowel. The two trowels I recommended above will not cause thinset to purge with that particular tile. Of course the thinset must be combed and controlled and not allowed to heap anywhere. This is really easy stuff to do.
Keep a damp sponge at the ready just in case. If necessary immediately wipe away any purges and the sponge will dig deep enough that grout will later cover the depression the sponge makes in the grout.
Ask me how I know.
XXX
Old 03-30-2011, 07:44 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 388
That would limit your grout choices quite a bit. It wouldn't do much good anyway though. White thin set isn't like white grout, same for gray. You gotta use the right trowel and technique, and go back and cut out any Oppps.
There's gonna be lots of Oppps with those 1/2" beauties.
Jaz
Old 03-30-2011, 07:48 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Maybe I should ask; Are these tiles ceramic or are they the real coppers wrapped around a backer?
XXX
Old 04-02-2011, 04:32 PM   #9
Sorry my CPU was out for a couple of days.
These tiles are glass colored brown and copper color, so I'll be using non sanded grout I guess as I don't want to wear off the color or scratch them.
Old 04-02-2011, 04:34 PM   #10
I always scrap out any thin set that creeps up between the tiles with a knife or screw driver so I'm thinking I can do the same with the tiles. I was told that I should not use thin set on dry wall as it does not adhere well, that I should use a product called mastic.
Opinions?
Old 04-02-2011, 05:47 PM   #11
Tileguy
JazMan's Avatar
Rewards Points: 388
Oh really? Who was the genius that told you that? What does the glass tile manufacturer say to use? Never seen a mastic made for use with glass tiles. Can you share one with us?
Jaz
Old 04-02-2011, 05:57 PM   #12
I belong to a boating forum and many members are do it yourselfers and a few GC also.
A few members said not to use thin set on dry wall and that mastic worked better. a couple of guys said that mastic should not be used in wet areas. Oters went on to say wet areas like a shower etc..
Me being a dummy don't know who to listen to!!!
Old 04-02-2011, 07:43 PM   #13
Tileguy
JazMan's Avatar
Rewards Points: 388
Mastic will work well for dry areas such as a kitchen backspalsh. Although it's 4-5 x more expensive and not as good, it's fine for some jobs.
I don't know of a mastic that should be used for glass tiles. All you gotta do is read the tile manufacturer's directions, and any can of mastic.
Jaz
Old 04-03-2011, 11:33 AM   #14
The only benefit of using mastic is the non sag properties and since it is never recommended for glass installation,(that I know of) I would use thinset.
I would probably use a high quality non sag thinset like mapei ultralite, kiesel servolite etc, although this is probably overkill.
MCTF is offline   Reply With Quote
Old 04-05-2011, 10:30 AM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Utter NONSENSE! Tell those guys to stay with boating and we'll handle the tile inquiries here. Don't try to use any mastic for glass tile installations. Use thinset - even on drywall.
XXX
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
Grouting Fireplace Tile Question roxksears Building & Construction 4 11-29-2009 07:21 PM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
