Grouting Between Small Natural Tiles - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 08:30 AM   #1
grouting between small natural tiles
I have put up the 12x12 sheets of small natural stone and glass tiles. The area that needs to be grouted is about 1/16 wide. I can't use a float and cover with grout and wipe because the stones are not flat and smooth but vary in height and texture. Is there a way to grout in between with some type of grout bag?
boxerart is offline   Reply With Quote
Old 01-14-2013, 08:42 AM   #2
Rewards Points: 14,300
Grout bag, pastery bag, will work, use unsanded grout. Do not leave any haze on the tiles.
Depending on what type stone it is it may be best to seal the tile before grouting so it does not get stained.
Old 01-14-2013, 10:24 AM   #3
Do they have tips small enough to get into the cracks? I do plan on sealing this, it's the whole front of my fireplace, but again, the tiles have so many "dimensions", some flat some very very rough etc....
Old 01-14-2013, 11:22 AM   #4
Then use a pastery bag, there's dozens of differant tips.
There's just not perfect way to do this, the grout has to be forsed into the gaps so some of it's going to get where you do not want it.
boxerart (01-14-2013)
Old 01-27-2013, 11:09 PM   #5
As i think there is no way to solve this problem. as per i think you should clean the whole floor buy pres surely thronging water on it and then take the water out by large towel or clothing this will take a hell of time but is the essayist way to do it.
paulsmith544 is offline   Reply With Quote
Grouting vinyl peel and stick tile Pnkhollie09 Flooring 2 03-21-2012 03:03 PM
Where to buy natural stone tiles? Girlfriday7d Flooring 8 01-05-2012 10:39 PM
How to/what to use to cover potentially asbestos tiles? TomServo Flooring 7 09-10-2009 11:59 AM
Can I lay natural stone (travertine) tiles directly on the subfloor? horizontal8 Flooring 7 08-15-2009 08:43 AM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 03:07 PM
