Grout Turns White When Dry - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 12:31 PM   #1
Rewards Points: 640
Grout turns white when dry
I got my tiles down, and got them grouted, followed instructions exactly the way the bag said... I put down a TEC grout, the color is "Pearl" which is a light brown / tan color. It looked the grout was the right color when mixed, the consistancy was right, the color was right when it was on the floor. waited the 60 minutes the bag said before wiping the haze off the tile did it with a ringed out sponge wiped off the tile after with a terry coth towel like it said, let it dry, grout is now white... wipe the grout with a clean spounge again after it set a couple days, it turns the right color, then dries white again...
followed directions exactly, how do I get this what I think is a white haze off? thanks!
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 09-24-2012, 02:20 PM   #2
Rewards Points: 640
no suggestions?
I've done the wipe and rub a few times now... the tiles themself are clean with no haze, the grout just keeps going back to white when it drys.. looked at using a haze remover, but it says to let the grout cure for a few days first
Old 09-26-2012, 03:20 PM   #3
Rewards Points: 640
oops, just realized I posted this in flooring instead of the tile section sorry! Don't know what I was thinking, mind must of thought its floor tile saw flooring and clicked on that... can someone move this? thanks
Old 09-27-2012, 05:15 AM   #4
DIY staff
Rewards Points: 7,174
Try using an 'enhancing' stone sealer----you may need to go to a tile store for that product.
Moved the thread for you----tile---
White Haze on Grout?? Jlail9905 Flooring 9 06-24-2012 01:08 AM
How can I remove grout sealer white taint? sukhenkoi Kitchen & Bath Remodeling 2 07-29-2011 10:52 AM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 07:07 PM
Using white thinset with dark grey grout. sukhenkoi Tiling, ceramics, marble 5 04-20-2010 06:54 AM
Will white grout stay white if sealed? fix it Flooring 3 12-01-2009 07:44 PM
