Grout Removal From Tiles - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 12:14 PM   #1
Grout Removal from Tiles
I have a lite glaze of grout on my tile that I can't remove. Water doesn't do anything. I've used vinger & water but no success. Will muratic work or does Lowes or Home Depot have something less abrasive? Please help..
Olen Boykin is offline   Reply With Quote
Old 07-27-2011, 01:53 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
I believe they do make a haze remover. Check with a tile store if you can't find it in an apron store, but it will still take a lot of elbow grease
Blondesense is online now   Reply With Quote
Old 07-27-2011, 02:34 PM   #3
Haze remover and a 3M nylon scrubbing pad should work. Haze Remover should be with the sealants.
superspeck is offline   Reply With Quote
Old 07-27-2011, 08:28 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 226
Hard to tell, but sounds to me that you have more than a little haze, but can't tell from here.
Will muratic work
If you use muriatic acid indoors, we may have to visit you in the hospital. It can also damage your home. Do not do that.
If white vinegar or haze remover doesn't work, wait 10 days (after initial grouting date), and try Sulfamic acid crystals per directions.
Jaz
Sanded or unsanded grout for the shower surround wall tiles? nitting Tiling, ceramics, marble 10 11-30-2012 09:45 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Removing grout from top of ceramic tiles markdrum1 Tiling, ceramics, marble 3 09-28-2010 10:38 AM
Do I need to grout fireplace tiles? xiard Remodeling 4 04-17-2009 08:19 AM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 04:07 PM
