Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 11-21-2008, 03:46 PM   #1
Grout lightened after sealing
Hello. I just had an outdoor patio tiled by a pro (he did a fantastic job by the way). I decided to seal the grout myself and after doing some web research, decided upon Aqua Mix Choice Gold sealer, one of the most expensive options. My grout was a terra cotta color, medium hue, but after sealing it, the grout lightened quite a bit. It looks almost pink now. I was told that grout tends to darken after sealing. Darker would have been a better outcome. Did I go wrong somewhere? OK, OK, I didn't test a patch first, but after spending $120.00 a gallon, I figure I couldn't go wrong.
SueT is offline   Reply With Quote
Old 11-21-2008, 06:25 PM   #2
Tileguy
Bud Cline's Avatar
Rising moisture.
Old 11-21-2008, 08:42 PM   #3
Thanks Bud, but could rising moisture happen when...
The tile was set on a covered, outdoor patio that never gets wet. The foundation was a concrete slab that had a few old cracks in it. The tile guy cut expansion joints into the concrete, roughed it up, poured a layer of "something" to level the surface, laid a slip sheet, waited three days, then set the tile and grouted. The weather was in the high 80's and very dry. Under these conditions, could moisture be a problem? Any other ideas?
Old 11-21-2008, 11:40 PM   #4
Tileguy
Bud Cline's Avatar
Moisture can always be present in concrete on grade.
Old 11-22-2008, 08:14 PM   #5
So, should I have waited longer before applying the sealer?
Old 11-23-2008, 09:05 PM   #6
Tileguy
JazMan's Avatar
I'm not sure? It could be moisture, but Sealer's Choice Gold allows moisture transmission so excess moisture evaporates through the sealer. Usually too much moisture will make the tile look cloudy. Is it possible you used too much sealer and didn't wiped off the excess before it dried? Not removing the sealer that didn't absorb will turn white as it dries.
Penetrating sealers do not change the appearance of the tile or grout. Enhancing sealers will darken grout and some types of unglazed soft bodied tiles and most stones. I've not heard or sealers lightening grout, unless too much was applied and not wiped per directions.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 11-23-2008, 09:58 PM   #7
Tile and Paint contractor
What have you used to clean?
Acids and ammonia-based cleaners will discolor grout.
Also, when the grout was cleaned after installation, if there was excessive water used for rinsing, it could lighten the color of the grout.
It may even been your sealer. Although, I never had a problem with anything made by Aquamix.
But, ALWAYS test an area before using any kind of liquid product on grout or tile.
Matt | tile contractor
Charlotte, NC
MattCoops is offline   Reply With Quote
Sealing grout for outdoor granite sidewalk TVM Tiling, ceramics, marble 17 02-16-2009 08:09 PM
Sealing Grout qvminich Building & Construction 4 08-24-2008 06:56 PM
sealing tile grout questions 4just1don Remodeling 5 06-27-2008 06:37 PM
Sealing grout Crysgrits Flooring 2 02-26-2008 04:13 PM
sealing grout, how many coats? Yeti Flooring 1 10-19-2007 11:23 PM
