Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 12-31-2011, 11:11 PM   #1
grout discoloration and grout sealer
My shower has new tile and grout - the work was done by an installer. The problem is that the grout color is not even and it still gets dark in some places when wet. First, is this just a cosmetic issue? Second, is there anything we can do to fix it? Note: we have already sealed the grout and calling the original installer is not an option.
sarahrg is offline   Reply With Quote
Old 12-31-2011, 11:27 PM   #2
Tileguy
Bud Cline's Avatar
http://www.diychatroom.com/blogs/gro...rstandings-95/
Old 01-01-2012, 09:12 AM   #3
So does this mean that the grout discoloration is a cosmetic issue only? Also, is the uneven color something that can be fixed somehow?
Old 01-01-2012, 01:58 PM   #4
Tileguy
Bud Cline's Avatar
Does the grout return to an even color overall when allowed to dry?
Old 01-01-2012, 05:15 PM   #5
No. The grout color is uneven.
Old 01-01-2012, 11:06 PM   #6
Tileguy
Bud Cline's Avatar
That condition is typically caused from varying levels of tile adhesive in the grout joints when the grout was installed. Installer error.
Tile adhesive that is allowed to purge randomly between tiles and not cleaned to a consistent level prior to installing grout will cause grout to cure at different rates thereby causing grout mottling.
Old 01-02-2012, 09:45 AM   #7
Thank you. Does curing at different rates mean that it will eventually even out? It has been 2 months and it is still an issue.
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 08:07 PM
Caluking instead of grouting tile in shower? KansasWind Flooring 5 03-30-2008 11:43 PM
sanding grout C99 Flooring 4 02-18-2008 06:10 PM
Tile discoloration by grout jngtexas Flooring 5 01-28-2008 08:30 PM
Spectralock Grout? lavender Flooring 1 08-02-2005 04:52 PM
