-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   grout discoloration and grout sealer (http://www.diychatroom.com/f84/grout-discoloration-grout-sealer-128355/)
sarahrg 12-31-2011 10:11 PM
My shower has new tile and grout - the work was done by an installer. The problem is that the grout color is not even and it still gets dark in some places when wet. First, is this just a cosmetic issue? Second, is there anything we can do to fix it? Note: we have already sealed the grout and calling the original installer is not an option.
Bud Cline 12-31-2011 10:27 PM
http://www.diychatroom.com/blogs/gro...rstandings-95/
sarahrg 01-01-2012 08:12 AM
further question
So does this mean that the grout discoloration is a cosmetic issue only? Also, is the uneven color something that can be fixed somehow?
Bud Cline 01-01-2012 12:58 PM
Does the grout return to an even color overall when allowed to dry?
sarahrg 01-01-2012 04:15 PM
grout color
No. The grout color is uneven.
Bud Cline 01-01-2012 10:06 PM
That condition is typically caused from varying levels of tile adhesive in the grout joints when the grout was installed. Installer error.
Tile adhesive that is allowed to purge randomly between tiles and not cleaned to a consistent level prior to installing grout will cause grout to cure at different rates thereby causing grout mottling.
sarahrg 01-02-2012 08:45 AM
Thank you. Does curing at different rates mean that it will eventually even out? It has been 2 months and it is still an issue.
