Grout Or Caulking Or Both Around Bathtubs - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-11-2012, 01:10 PM   #1
Grout or Caulking or both around bathtubs
Should grout, caulking, or both be used around bathtubs where they abut tile walls and floor ?
Amaryllis is offline   Reply With Quote
Old 04-11-2012, 06:59 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Silicone color to match your tile. Why silicone Around the tub? because the tub can flex slightly and crack the grout.
JetSwet is offline   Reply With Quote
Old 04-11-2012, 07:07 PM   #3
DIY staff
Rewards Points: 7,174
Jet Swet is correct--calk in all 'change of planes'--things move--grout doesn't--so a waterproof flexible caulk is the answer---Mike---
JetSwet (04-11-2012)
Old 04-11-2012, 07:48 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 422
Unanimous. Every grout maker also has caulk to match their grouts both in color and texture. I think it's usually siliconized acrylic, use it.
Jaz
Old 04-22-2012, 08:35 PM   #5
Isn't the rule caulk any 90degree connections? (corners, trim to tile, etc)
DIYGuy2012 is offline   Reply With Quote
Old 04-22-2012, 08:52 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 422
No. The angle doesn't matter. You should caulk at all changes of plane and dissimilar substrates. You can sometimes get away with grouting inside corners if the structure is sturdy, but not very often. Always caulk around tubs and any other similar situations.
Jaz
New grout and caulking on bathtub John84 General DIY Discussions 1 08-09-2011 06:06 AM
Caulking large gaps in shower enclose+to caulk or grout a tub with tile. pilsengirl Plumbing 1 07-31-2011 12:36 PM
caulking shower stall questions, removal, grout sealing etc detyianni Plumbing 0 11-29-2010 09:00 AM
Grout, caulking or both??? upinsmoke Plumbing 21 06-01-2010 09:13 AM
silicone caulking over ceramic tile grout joints tonyg2 Flooring 5 11-16-2008 08:48 AM
