Grout Or Caulk Shower? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-21-2009, 04:18 PM   #1
Grout or caulk shower?
I replaced a cracked bottom tile and cut away the grout line where the wall meets the floor in the shower all the way around. Everything is sound so here's my question. Do I still grout where the wall and floor meet or should I use a silicone caulk? Should I use a sanded or non sanded grout around the tile I replaced and what's the difference? I don't know if the existing grout is sanded or non sanded.
Joe Vieira is offline   Reply With Quote
Old 02-21-2009, 04:59 PM   #2
Remodeling Contractor
small joints like those on a wall use non-sanded grout. It is finer and fits better in smaller joints. The larger aggregate like in a sanded grout is used for larger joints where more strength is needed. Use a caulk colored to the grout color for the wall to floor and wall to wall transitions.
Old 02-21-2009, 06:54 PM   #3
K&B Remodeler/Tile Guy
angus242's Avatar
1/8" or small joints use unsanded grout.
The transition from wall to floor, or any change in plane, gets caulked, not grouted. Be careful if you use a caulk that's color matched to grout. Not all of them are acceptable to use in areas that are susceptible to excessive water, like the wall to shower floor joint. Read the instructions before you buy it.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 02-22-2009, 08:02 AM   #4
Both Mapei and Dap make caulks to match their grout.
Old 02-22-2009, 10:48 AM   #5
Tileguy
JazMan's Avatar
Rewards Points: 290
Is there a grout company that doesn't make caulk to match all or most of their grouts? These caulks are acrylic or siliconized acrylic. I do not recommend regular silicone caulk for tilework.
Jaz
JazMan is online now   Reply With Quote
Old 02-22-2009, 11:42 AM   #6
Thanks for all the helpful info.
Newbie Joe
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
Shower floor grout cracking radnrs Flooring 11 09-14-2008 09:49 PM
Grout before Caulk around bathtub? bsippl Building & Construction 6 08-19-2008 09:57 AM
Cracking Grout Between Shower Tiles average General DIY Discussions 9 05-08-2007 03:20 PM
Can you caulk over grout lines in a tile shower? Greg General DIY Discussions 7 11-20-2006 06:20 PM
