Is This Good Tile/grout Work?? - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-13-2013, 10:59 AM   #16
Rewards Points: 296
Originally Posted by jeffnc View Post
If they had really waterproofed the shower correctly, it would only be cosmetic cracking of the grout later. However, the more important issue is how they waterproofed it. That's really the major issue to get right.
I am fairly confident they did the waterproffing correctly so not too concerned.
Eagle One is offline   Reply With Quote
Old 09-13-2013, 11:56 AM   #17
Rewards Points: 4,780
It's not regular caulk - it's a matching sanded product that is flexible. However, cracking trumps most other issues.
Besides, quality tile caulks are also mold/mildew resistant.
http://www.mapei.com/public/US/produ...S&U_TDS_EA.pdf
jeffnc is offline   Reply With Quote
Old 09-13-2013, 12:46 PM   #18
Rewards Points: 296
Looks like a good product to use in the future if I get cracking of the grout and it seems like you can just put it over top of the grout, right? Maybe I just DIY this in the future as I know the contrator will NOT bother with it now.
Old 09-13-2013, 12:53 PM   #19
Well, yes you can put it over cracking grout, but the crack line might be too narrow for sanded caulk to hold well in. The point is to put something in there that has some flex. Aesthetically, if the crack is small, some unsanded caulk might be best to cover.
Again, if the shower is waterproofed correctly (and I'm guessing you'd be surprised at how many are not), then cracks inside the shower shouldn't cause damage - they just look bad. However cracks on the outside can cause damage. For example, I always see grout on the floor tile, right up to the bathtub. This is really bad, because water always trickles down the sides and corners of the tub during a shower or when you step out. If there's a crack there, then the water is trickling right down into your subfloor, rotting and causing mold. The same thing can happen without a tub - on the outside corner of the floor to the shower curb. Although with a tub it's even more likely to crack.
Old 09-13-2013, 02:10 PM   #20
Rewards Points: 296
Ok, cool. Thanks for all the info.
Old 09-20-2013, 02:26 PM   #21
Rewards Points: 77
I know it's been a few days, but I'm pretty sure any corners or corner-like joints should be caulked in some fashion due to the flex between the two different planes WILL cause the grout to crack. So any 90 degree edge should be caulked. I know you only took pictures of that mess, but I bet the rest of the corners weren't caulked either.
dengle is offline   Reply With Quote
Old 09-20-2013, 03:42 PM   #22
Rewards Points: 1,016
If this is the way they did things you can see, I would be extremely concerned about the quality of things you can't see...
____________
Vince
Old 09-20-2013, 05:15 PM   #23
747
registered
747's Avatar
Rewards Points: 534
STOP with hold final payment. This is un acceptable TILE WORK.
747 is offline   Reply With Quote
Old 09-20-2013, 05:38 PM   #24
Exactly.
Old 09-20-2013, 10:33 PM   #25
Rewards Points: 918
I don't like the travertine cap either. I'm thinking all the little holes in that are a mold machine.
cleveman is offline   Reply With Quote
Old 09-23-2013, 02:06 PM   #26
Rewards Points: 296
Had a meeting with the lead and sub contractor to work out the issues. The sub mentioned caulking the tiles before I even said anything and they are going to fix it that way. Have to order the special colored caulk to match and it should be handled soon. The lead is going to warranty all the work so I am not worried about it and I have spoken with the sub a lot and trust the guy that the shower underlayment was done right. This grout thing was just a goof and he knows it and will fix it. The rest of the work is actually pretty good.
Work related: Too good to be true. Doc Holliday Off Topic 10 04-07-2013 11:36 PM
work schedule redman88 Off Topic 16 03-28-2013 08:50 PM
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 04:19 PM
Can homeowner (or friend) rewire in California? cvandewater Electrical 34 01-14-2012 01:04 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 11:07 AM
