Glass And Ceramic Tile Thickness - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-21-2011, 04:58 PM   #16
I installed some glass tile on my backsplash and remember that I had to comb the thinset in a horizontal manner so that the trowelmarks wouldn't show through the glass. (Translucent white glass)
Not sure if it's pertinent but thought I would share...
williamwiens is offline   Reply With Quote
Old 03-21-2011, 05:11 PM   #17
Thanks william, the glass is translucent so i will keep that in mind.
Bud. I guess what i was saying was I didn't think i would be able to trowel a smooth wall since my skills aren't professional grade and as I got close to the lip of the tub it would be even more difficult to keep it clean and off the tub. I am trying to avoid hours of sanding. Since the 1/4" cbu would work I'll go that route. Much easier and faster.
onthebrink is offline   Reply With Quote
Old 03-21-2011, 05:20 PM   #18
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Works for me!
That's what the notched trowel will do for you. It will cause you to trowel-on thinset in a perfect consistent thickness.
A wet sponge would be handy for that reason.
Never mind. If the seam ( next to the upper tile) where the cement board starts will work for you it's a good idea to use the board instead.
XXX
Can I adhere ceramic tile onto wood kairokeevy Tiling, ceramics, marble 15 03-20-2011 07:36 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 08:50 PM
dura ceramic sparky9999 Flooring 20 03-03-2009 11:43 AM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 09:01 AM
Custom built legs for very large glass tabletop joeyboy Project Showcase 8 10-06-2008 10:48 PM
