Glass And Ceramic Tile Thickness - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-17-2011, 01:43 PM   #1
glass and ceramic tile thickness
I am going to install tile around a bathtub with the bottom 2-3 feet being 1" glass mosaic tile and the top half being ceramic. The ceramic tile is much thicker than the glass, about a 1/4". How do I build out the wall to make them even?
onthebrink is offline   Reply With Quote
Old 03-17-2011, 04:13 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can use a square-notched tile trowel to evenly and neatly spread modified thinset on the wall. Then the next day use a large sanding block to flatten out any humps or bumps or mis-guided trowel marks. Then, apply another coat of modified thinset to fill the grooves only this time use the flat side of the trowel.
At this point you can compare the two tiles side by side on the wall and either add more thinset or sand off more thinset until you have the proper thickness of fill on the wall.
Piece-o-cake.
What's next?
XXX
Old 03-17-2011, 05:07 PM   #3
Excellent, thank you very much. Would you install the top tile first then build up the wall or build up the wall, do the bottom tile then the top tile?
Old 03-17-2011, 06:49 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I think I would install the thicker tile (top tile) first so I would know exactly where I needed to be when lifting the thinner tile.
Keep in mind the thinset behind the top tile will push out the tile a little.
XXX
Old 03-18-2011, 01:40 AM   #5
PatrickGSR94's Avatar
Rewards Points: 87
Just curious, if you do the upper tile first, how do you support the tile to keep it from falling off? I ask this if by chance you're doing a larger tile above.
PatrickGSR94 is offline   Reply With Quote
Old 03-18-2011, 05:11 AM   #6
DIY staff
Rewards Points: 7,174
Before setting the first row of heavy tile ----screw a wood ledger board to the wall-----Mike---
Old 03-18-2011, 10:42 AM   #7
Rewards Points: 87
lol duhh, I've done that before with upper cabinets
Old 03-18-2011, 12:01 PM   #8
Ha, thanks. I didn't even think of that. Its my first try at doing tile so it should be interesting.
Old 03-18-2011, 12:58 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 422
Hi all,
Yes it could. Are you using any waterproofing on the walls first? Specifically what are you using as an adhesive?
I always get a kick when people select tiles of different thicknesses. It can create problems, not to mention all the extra time. But you can do it, be careful cuz it can get messy. Next time you can buy thicker glass tiles instead.
Jaz
Old 03-18-2011, 01:30 PM   #10
Originally Posted by JazMan View Post
Hi all,
Jaz
Well, if I had my way I would have done one tile all around but since my wife is the decorator I choose not to fight this battle. She bought the tile before I could really say anything.
I put up cement backer on the walls with a vapor barrier. I've got some thinset mortar as adhesive for the tiles.
Old 03-18-2011, 02:11 PM   #11
Tileguy
JazMan's Avatar
Rewards Points: 422
OK, that's good and more than lots of people do. The "barrier" is on the studs under the CBU, right? It's not really a "barrier", it a vapor retarder.
I was hoping you'd be specific as not all thin sets would be appropriate for your installation.
Jaz
Old 03-18-2011, 02:40 PM   #12
Yes, the retarder is between the CBU and the studs.
Not sure what kind of thinset I have since its not sitting in front of me and I'm at work.
What would you recommend?
Old 03-18-2011, 05:13 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Glass tiles generally require a specific thinset. The garden variety entry-level thinsets available at home centers typically doesn't qualify for use with glass. You can get proper thinset recommendations from the glass tile manufacturers.
XXX
Old 03-21-2011, 12:50 PM   #14
So i put up the upper tiles and I need to build the wall out 1/4". Would it be possible to use 1/4" cbu over the 1/2" cbu instead of troweling on all that mortar? The space is 3 feet high on three walls directly above the tub. About 30 sq ft of space. My biggest concern is where the wall meets the tub and being able to get it set properly with out the wall resting on the lip of the tub.
Old 03-21-2011, 04:48 PM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Absolutely!
I guess I'm not seeing that as a probelm. Maybe I'm missing something. If that much additional wall thickness (plus the tile thickness) doesn't move your wall surface out too far as it relates to any curvatures of the tub, go for it.
XXX
Can I adhere ceramic tile onto wood kairokeevy Tiling, ceramics, marble 15 03-20-2011 07:36 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 08:50 PM
dura ceramic sparky9999 Flooring 20 03-03-2009 11:43 AM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 09:01 AM
Custom built legs for very large glass tabletop joeyboy Project Showcase 8 10-06-2008 10:48 PM
