#1 |
gap patch between shower walls
I have a shower pan (plastic?) and 3 walls with tiles. I am cleaning some old caulking along the tile walls and shower base. At the gap of two walls connecting and close to the shower base, I remove the caulking too hard, so I pulled out some harden white piece (I guess it is old thinset), the more trouble is that I "scooped" a narrow piece of the green drywall out.
I plan to put some thinset back into the gap and caulk it. Does it sound ok? Thanks |
#2 |
Without a picture it's hard to say.
#1 It's never a good thing to have sheetrock in any wet area, sure it's not failing? |
#3 |
sorry I do not have picture now, but I am pretty sure there is green sheetrock behind the tile. I think it is from the builder when the house was built in 1989. But I do not redo the whole shower. Initially I just want to clean the old caulk and recaulk as a maintenance.
#4 |
As long as the tiles are still firmly attached and there's no mold that keeps growing through you should be fine.
Any I see that old with just sheetrock are falling apart. |
#5 |
The tiles seems to be sound right now. I will go ahead to fill the gap with thinset and caulk.
Thanks |
| Display Modes | |
| lay out of tiles on shower walls | GBH1 | Plumbing | 2 | 02-06-2013 09:30 PM |
| Laminate flooring for shower walls?? | qwertzy81 | Flooring | 4 | 11-26-2012 09:52 PM |
| Need to replace 34 x 48 shower base (has surround walls inside shower base lip) | justplumducky | Plumbing | 3 | 09-10-2011 10:59 PM |
| Shower Base with Concrete Walls | Matt Staben | Tiling, ceramics, marble | 4 | 07-08-2011 12:18 AM |
| Acrylic shower walls, cement board needed? | SDG | Plumbing | 3 | 10-01-2008 08:05 AM |
