Flooring, Bud Cline, Are You There? - Tiling, ceramics, marble - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-06-2010, 07:20 PM   #16
Tileguy
Bud Cline's Avatar
Rewards Points: 558
JazMan: "The acceptable span? That is why I keep axing about the species and grade. You said 125", so 10'5". I checked the span chart using grade #2 at 50/20 and you're right at the border line or just above with most common species. You failed if the joists are Spruce-Pine-Fir South. There are other species. Joists are usually marked with the info."
So...Jaz...Do you still disagree with me? Sounds as if maybe you are slowly becoming a convert.
XXX
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
