Flexbond Or Versabond For Tile Over Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 05:39 PM   #1
Flexbond or Versabond for tile over tile
I have two non-traditional tile jobs I'm wanting to do, and the guy in the flooring dept at Home Depot told me that these two products would work. He said using Flexbond, I could tile over existing tile, without anything else in between. Also, Im wanting to Tile a laminate kitchen countertop, he said that both products would work, but the Flexbond would do the best job. Can anyone tell me if this is a bad idea or if it will work? And on the countertop, would I need to sand and scuff it first? Ive done tile work before, but it was regular jobs with regular thin set and concrete board. Any feedback would be appreciated. Thanks.
benlminton is offline   Reply With Quote
Old 08-28-2012, 02:18 PM   #2
According to the technical data sheet, Flexbond requires both surfaces to be sanded or scarified prior to application of the setting material. MAPEI has a special primer called ECO Prim Grip that you roll on like a paint, allow to dry and go over with a polymer modified setting material like the ones you mentioned. This eliminates the sanding process and all the dust it creates.
Inner Circle is offline   Reply With Quote
The Following User Says Thank You to Inner Circle For This Useful Post:
benlminton (08-28-2012)
Old 08-28-2012, 07:56 PM   #3
thank you so much for the response. so if i put the mapei product on, even the glazed tile, then i could just use the flex bond as i would regular thin set on cement board? Thanks again
Old 08-28-2012, 11:19 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 240
Ben, (?)
I think it would be best to also use the Mapei thinset recommended if you use the ECO primer. Otherwise follow directions for the FlexBond. I vote the the Mapei system if you can find it.
Jaz
JazMan is online now   Reply With Quote
Old 08-29-2012, 10:50 AM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
It's amazing how box store guys will tell you anything just to sell a product.
Deglaze the old tile regardless.
JetSwet is offline   Reply With Quote
Old 08-30-2012, 07:30 AM   #6
Since the ECO Prim Grip is a Mapei product, it would make sense to use a Mapei thin-set so you have single source responsibility. To my knowledge, Custom does not have a similar product to ECO Prim Grip. Yes, you can use the ECO Prim Grip over both the tile and the plastic laminate. Just make sure both surfaces are clean.
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 11:43 AM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
VersaBond vs. FlexBond mklang Flooring 7 12-13-2010 04:23 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
