Flattening Plywood Underlayment - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-21-2013, 08:06 AM   #1
Rewards Points: 16
Flattening plywood underlayment
Need some advice on the best way to flatten my plywood underlayment.
I am putting 1/2" plywood on top of the existing 1 x 8 diagonal floor boards and there are some some low and/or high spots (+-3/8") in the existing floor. What is the best way to flatten these out?
I don't think SLC will work very well because the floor is a little bit out of level and it will cause some issues at a doorway.
Should I try to fill in the low spots before putting down the 1/2" plywood? If so, using what?
Or should I deal with it after I put down the plywood (but before I lay down the Ditra)?
Is it possible to use thinset and a straight edge to fill in the low spots with thinset?
MalcolmReynolds is offline   Reply With Quote
Old 06-21-2013, 09:22 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
I personally wouldn't go anything less than 3/4" T&G.
I'm doing a 2-story addition to my house. Upstairs I used 1 1/8" T&G. Initially, when I first saw this on the plans I commented on it to the architect....he said "Trust me, you will be glad"
He was right...I'm glad. It's about par to walking on concrete. FLAT.....and solid.
Downstairs I have 3/4" T&G for my subfloor....now I'm wishing I had used 1 1/8"
Considering replacing playwood subfloor, many questions. gante Flooring 3 04-12-2010 11:39 PM
Subfloor and Underlayment Questions JulieZ Tiling, ceramics, marble 14 06-23-2009 08:04 AM
Underlayment for Hardwood datavortex Flooring 3 11-09-2008 04:49 PM
Sheet Vinyl....plywood underlayment or luan? AllGoNoShow Flooring 3 05-28-2008 05:57 PM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 12:12 AM
