Fitting A Replacement Floor Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-03-2010, 07:30 AM   #1
Fitting a replacement floor tile
Hi having difficulties replacing a floor tile, I have managed to take up broken tile without any problems. However I can not seem to get the replacement tile to fit back in place, itīs a tile surrounded on three sides by tiles and the fourth by a wall. No matter how I jiggle the tile I only manage to get two sides to slide into place. Anyone have any ideas its driving me crazy been at it 3 hours trying to make it fit. PS its a tile I had from the original box of tiles when the floor was laid.
applemac01 is offline   Reply With Quote
Old 03-03-2010, 07:39 AM   #2
DIY staff
Rewards Points: 7,174
Did you chisel out the grout? Scrape out the old firmset? Was the original tile cut at the wall?
applemac01 (03-04-2010)
Old 03-03-2010, 08:25 AM   #3
Yes I have at least I cant see anymore left
Old 03-03-2010, 08:35 AM   #4
DIY staff
That's strange----------I'm sure you took a ruler and measured the existing tile--and the replacement.
How big is the grout line? I've got to go to work soon, There are several tile pros here--someone else will offer a solution.
If you can post a picture it would help.(I'll understand if you don't--I'm computer impaired myself)
Good luck! I'll check in tonight.--Mike--
Old 03-03-2010, 11:49 AM   #5
Kitchencarts360romona
romona's Avatar
When that happened to us in my laundry room, we tried for hours and couldn't get it to work. Finally, we called a pro and he said sometimes that happens if you don't sand the grout off. For some reason we did that, and after my hubby shaved a little with somekind of tool it fitted. Just an idea . It was so frustrating when that happened. One tile in my kitchen has a couple cracks, and I am not excited to tackle that.
Hope it turns out well.
Romona,
Publisher,kitchencarts360.com
romona is offline   Reply With Quote
The Following User Says Thank You to romona For This Useful Post:
Old 03-03-2010, 12:03 PM   #6
Mike,
They are the correct size, from the builder of the house when we moved in left us supplies of spare tiles used just in case of issues like this. Anyway after trying to clean some more I accidentally broke the tile next to it, although I have now remove that tile also. The problem persists as now the original tile will fit but the whole let from the one I broke wont. Begining to think it might be best taking the line back to the wall and then usuing the fact the last tile is not a full one by cutting it will solve the issue.
Old 03-03-2010, 02:02 PM   #7
Newbie Bill
Rewards Points: 520
Hey Applemac, Can you post a picture of the area and the replacement tiles?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
The Following User Says Thank You to drtbk4ever For This Useful Post:
Old 03-04-2010, 08:44 AM   #8
Well ive solved the issue now, as I was lucky enough to have a couple of boxes of tiles from the builders of the house, what Ive done is taken out the tiles back to the wall. This has enable me to fit the tiles without an issue.
Interior stop trim after installing replacement windows not fitting correctly DyerWolf Carpentry 10 11-26-2009 10:53 AM
Rewiring a replacement light fitting charlie11051980 Electrical 4 02-28-2009 02:59 AM
fitting a replacement bath exhaust in a bigger hole mayhem69 General DIY Discussions 3 01-26-2009 06:04 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 06:30 PM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 04:12 PM
