Fireplace Tiling Question. - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-21-2013, 08:45 PM   #1
Fireplace tiling question.
I'm am currently in the middle of finishing my basement.
We have installed a double sided fireplace in a wall that separates two rooms. The fireplace is 4' wide by 16" tall and sits 3' off the ground to the bottom of the fireplace.
On both sides, the tile will cover 6' horizontally, then floor to ceiling. The walls are about 10' long and flat...no mantels or boxing out.
My question is in regards to where the tile will end on the bottom and meet the floor. The floor will be done in a carpet, most likely berber.
Should the tile sit tight to the concrete floor, or leave a gap?
The concrete floor isn't completely level, so I'm thinking I might have to start a bit higher up with a board screwed into the wall for support, and then back fill the bottom tile the next day.
Any suggestions, tips?
Cheers!
fubar79 is offline   Reply With Quote
Old 07-22-2013, 05:55 AM   #2
Rewards Points: 13,446
Always leave a gap where it meets the floor.
Old 07-22-2013, 09:39 AM   #3
Thanks joecaption.
I will be using edge protection/trim on the sides, should I use this on the bottom as well, or is it for aesthetics only? Is my best option using a temporary wood ledger?
Tiling Question bdavid50 Flooring 19 06-19-2011 05:35 PM
Take a look at my bathroom tiling and my fireplace yummy mummy Tiling, ceramics, marble 10 12-07-2010 10:57 PM
Tiling a fireplace. carinmc Flooring 2 01-22-2010 10:45 AM
Tiling Fireplace Bper Building & Construction 1 12-06-2008 12:02 PM
Fireplace framing question gobble Building & Construction 2 05-17-2008 10:01 PM
