Fireplace Retiling - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-01-2012, 08:52 AM   #1
fireplace retiling
can i grout tile over tile around fireplace?
phager001 is offline   Reply With Quote
Old 04-01-2012, 12:29 PM   #2
Rewards Points: 13,968
I doubt you would ever get the tile to lay flat that way. If it was mine I would go over it with tile board first then the tile. Use Tap Con Screws.
Old 04-02-2012, 12:17 PM   #3
Depends on what kind of tile surface it is. Try testing your idea by bonding a piece of tile on there with modified thin-set (spread thinset on existing tile) and let it sit for a day. The next day you tear it off and if all the thinset is sticking to the new tile instead of the old tile, then you know it won't work and you will have to rip it out.
FrolickTile is offline   Reply With Quote
Old 04-04-2012, 01:54 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
An absolute and resounding "YES" is the answer to that question.
Old 04-04-2012, 10:22 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
I wouldn't ever suggest tile over tile unless you take the finish off the top of the existing tile.
JetSwet is offline   Reply With Quote
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 11:37 AM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 09:26 AM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
