Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 10-16-2011, 06:47 PM   #1
Fireplace hearth dilemma
Hello, I have a unique situation which I would really appreciate advice on. I tore down my interior brick fireplace wall and hearth. My question is regarding the hearth, it's down to bare concrete the area that I need to tile is 18"x50". The problem I'm facing is the granite tile starting on the wall is 1" above concrete floor, the thickness of the tile is 3/8". I need suggestions on how to lift the tile about 1/2" off the concrete floor, otherwise the gap between the floor tile and the wall tile would be over 1/2". I thought of using hardi backer, then read that it cannot be attached directly to concrete, then I thought of using plywood and bonding with construction adhesive, read that wasn't a good idea as well.
FYI - The area is very small and will only be decorative.
Thanks in advance.
musa1227 is offline   Reply With Quote
Old 10-16-2011, 08:02 PM   #2
Tileguy
JazMan's Avatar
Hi,
Just thinking out loud...........was wondering why the new granite walls tiles are 1" off the floor, and why the floor tiles weren't installed first?
Easy solution. Spread a bonding coat of thin set on the concrete, place the appropriate thickness of "deck mud" (sand topping mix), spread, level, and double check by placing tile and beat in. Remove tile and back butter with thin set. Set tile.
I know you're wondering what the heck I'm talking about, so look at this video. Disregard the silly parts, but you should get the idea. Come back with your questions.
http://www.youtube.com/watch?v=E1NMJyc_2V0
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 10-16-2011, 08:37 PM   #3
Thank you for you prompt reply.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
would that be a suitable product? and would i just frame around where i need to set it, pour it in, spread it and level it? Also would I just put the granite tile directly on this or back butter as you said the tile after this is dry?
The reason I wanted the hearth 1" off the ground is so that it is slightly higher than surrounding flooring.
Thanks again for your help.
Old 10-17-2011, 09:22 PM   #4
Tileguy
JazMan's Avatar
Yup, that's the stuff. No frame needed. It's mixed kinda thick like in the video. Remember this stuff will not stick to concrete, you have to spread thin set on the concrete then on this mix for the tiles. You do all that in one step, you do NOT let the sand mix dry. Watch the video again.
Jaz
Insulating Fireplace hearth Red Truck General Discussion 1 02-07-2010 02:12 PM
Fireplace hearth zulusue Building & Construction 1 01-24-2010 11:00 AM
Fireplace facelife - needing hearth advice louiejr Building & Construction 4 11-25-2009 06:57 AM
Please Help with Fireplace Hearth Planning BobnSofi Building & Construction 1 02-18-2008 07:26 PM
Possible to build direct-vent fireplace? DIYerself General Discussion 3 12-22-2007 11:07 PM
