Fastening Wire Mesh To Hardibacker - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-26-2011, 06:16 PM   #1
fastening wire mesh to hardibacker
Are 1" crown staples driven pneumatically OK for attaching chicken wire to hardibacker? We have decided to float the backsplash because the framing is so wavy. My tile guy says he can't staple to hardibacker with his regular T50 staple gun.
John Sempek is offline   Reply With Quote
Old 04-26-2011, 07:24 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yow-well he's right about that!!!
A T-50 isn't a staple "gun" to begin with. And it wouldn't be anywhere near capable of using the correct staples.
Not sure what that* was supposed to have been but a 7/16" crown X 1-1/2" leg would be the staple to use, assuming the Hardi isn't over drywall. The thing is...the Hardi probably won't hold the staple anyway unless you were hitting a stud with every shot. That's what I would strive for.
XXX
Old 04-26-2011, 07:26 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I'm not sure how that's going to to work if the mesh is going to cause the mud to stand proud of the adjacent wall. Guess I don't know enough about what you are trying to do.
XXX
Old 04-26-2011, 08:13 PM   #4
straighten the wall first with some hot mud then screw the backer on and tile. actually if you straighten the wall with compound you wont need the hardibacker, it is ok to stick the backsplash tile to the drywall isnt it tile pros?
Old 04-26-2011, 08:50 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yup!
Yup! That's what I would do.
Use Durabond 90 and a straightedge.
No Hardi, no wire, no mud, no staples, no problem.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
oh'mike (04-26-2011)
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 09:36 AM
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 02:04 PM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 02:23 PM
do i need to use a scratch coat and wire mesh on cement board(floor) Limit54 Flooring 10 12-03-2009 07:24 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
