Fastening Drurock Question - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 02:53 PM   #1
Rewards Points: 280
Fastening Drurock question
Don't know why this ended up at the end of another thread?
I am asking a lot of questions lately! Anyhow some how I got it in my head (those voices again) that Durock should not be fastened closer than one inch from the edge of the panel. I have read a bunch and can find no reference to it?
My inside corners are 2X4 so 1/2" sheet on one wall leaves only one inch on the other. So would be closer than 1"
Is it OK to fasten closer than 1" from edge of Durock Next Generation? JIm
jjrbus is offline   Reply With Quote
Old 05-14-2013, 03:55 PM   #2
Remodeling Contractor
Sure you can fasten it close to the edge. Any way you can get a screw into the stud.
I think you might of been misunderstood and guys thought you were installing on the floor.
That way you CAN fasten a little farther from the edge - Make sense to you?
pgc555 is offline   Reply With Quote
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 08:11 PM
I&W around pipes and valley metal fastening diyroofer Roofing/Siding 0 09-12-2011 05:39 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
