Enlarge An Existing Hole In Ceramic Tiles - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-19-2012, 01:17 AM   #1
Rewards Points: 1,622
Enlarge an existing hole in ceramic tiles
I have a bath tub spout that needs to be replaced.
In order to install the new spout I need to thread a male adapter into the wall (it was using a nipple previously). The male adapter is slightly bigger in diameter and the tile on one side is too small.
I have a diamond hole saw to do it, but there is an existing hole so the bit has nothing to bite into. Since it's tiles I can't screw a piece of scrap wood to start it off.
Any ideas?
miamicuse is offline   Reply With Quote
Old 08-19-2012, 01:26 AM   #2
Rewards Points: 13,450
Roto zip with a tile bit will open it up.
Old 08-19-2012, 08:08 AM   #3
Rewards Points: 236
yeah, the tile bit will work well. i use one in a dremel.
Fix'n it is offline   Reply With Quote
Old 08-19-2012, 08:42 AM   #4
bbo
mount something in the hole for the hole saw to bite into. you don't have to fill the whole hole, just the part the hole saw needs.
bbo is offline   Reply With Quote
Old 08-25-2012, 10:50 PM   #5
Bombastic Idiot
notmrjohn's Avatar
Like bbo sed only mount a scap of wood on the back side of wall if you can get to it and if the bit is long enough.
My vote is with joe and fixin it.
notmrjohn is offline   Reply With Quote
ceramic tiles on existing floor dwp-56 Tiling, ceramics, marble 1 03-06-2012 09:12 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
Tiles over existing vinyl Work is good Flooring 3 07-11-2007 10:10 PM
Bathroom Tiling - On top of existing tiles??? moggiex Painting 8 12-13-2006 05:17 AM
