Durock Secured On Top Of Drywall For Shower Walls? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-09-2013, 04:46 PM   #1
Rewards Points: 682
Durock secured on top of drywall for shower walls?
Most tile shower installations I've seen look like durock or backerboard secured directly to the original drywall. The tile surface is a good inch+ on top of the surrounding original wall. Is this how it is being done? It would make a much easier installation.
darsunt is offline   Reply With Quote
Old 11-09-2013, 04:54 PM   #2
Rewards Points: 14,306
Never once seen it done that way and never want to.
Live_Oak (11-09-2013)
Old 11-09-2013, 05:55 PM   #3
747
registered
747's Avatar
Rewards Points: 534
Agree with Joe. Somebody is being lazy.
747 is offline   Reply With Quote
Old 11-09-2013, 06:24 PM   #4
How would you trim out the faucet if it was done that way?
The tile would be hanging out over the lip of the tub way to far to seal it correctly.
Old 11-10-2013, 10:08 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 422
That's a very common method of doing tub enclosures when doing a mud-job. Many tile setters also do it that way using tile backer as you described.
How are the ends finished? With regular mud cap just like in the old days. However, tile styles have changed and the use of mud cap and its availability is pretty limited these days.
The shower valve and tub contour present no problem. Wallboard, backer and tile is about 1 1/4", but the inside of the tub starts out about 1/4" away from the studs. It's been done that way for decades.
note: I do not necessarily recommend it today since we use different materials and we also use surface waterproofing, but it's still done that way everyday.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
Gary in WA (11-11-2013)
Old 11-12-2013, 12:53 PM   #6
Rewards Points: 682
Thanks, Jazman.
I've seen it done that way in a recent (expensive) remodel in a friend's home. I think it saves a lot of time, because you don't have to coordinate between the drywaller and the shower installer. The drywaller just sets all the bathroom walls, and then the shower installer can come in and set the durock on top for the shower whenever he wants, wherever he wants. The worst problem of that remodel was miscommunication and missed timing between different trades.
The only thing I like about that way of doing it is the shower wall ends up real solid, feels like solid rock. I took out my drywall and installed the durock to the studs. It looks much better, but when you bang the tile it echoes and feels like a wall.
drywall on skylight shaft walls above ceiling amakarevic Drywall & Plaster 5 03-25-2012 10:53 AM
Plaster walls with a new drywall ceiling Johnstrant Drywall & Plaster 2 03-05-2012 07:23 PM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 03:13 PM
Drywall or Denshield behind Shower Walls? atilla137 Plumbing 3 07-20-2008 09:11 AM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
