Durock Quarter Inch On Walls? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 01:14 AM   #1
Durock quarter inch on walls?
I'm working on new shower/bathroom area and I will be using steel studs for the frame.
My tile is 8"x48" porcelain tile. The Mfg http://mediterranea-usa.com/usa/boardwalk/ says it is a floor tile but looks great as a wall finish, which is what I will be using.
I purchased 1/4" Durock sheets for my tile backer because I didn't have to worry about matching existing drywall thickness. When I started to see what my required stud spacing would be for Durock, they say 1/4" is for floors. Can I still use this for walls when I'm using such large sections of tile?
Do I need to return this and get 1/2"?
7SistersRanchTX is offline   Reply With Quote
Old 03-23-2013, 06:48 AM   #2
DIY staff
Rewards Points: 7,174
Yes, you must use 1/2 inch for the walls-----those studs better be very flat---such large tiles require a perfectly flat wall---
Old 03-23-2013, 11:32 AM   #3
Tileguy
JazMan's Avatar
Rewards Points: 224
Absolutely no 1/4" CBU for walls. Be sure the metal studs are 20 gauge or thicker.
What's your plan for waterproofing? Is this a shower or tub surround? Have fun with those monsters!
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
Nailbags (03-23-2013)
Old 03-23-2013, 12:05 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Yeah, those tile are gonna be fun. Especially on a wall. I would definitely look into a tile leveling system with those things. There are several to choose from.
The Following User Says Thank You to Blondesense For This Useful Post:
oh'mike (03-23-2013)
Old 03-23-2013, 05:44 PM   #5
Jaz,
I planned on waterproofing with the roll-on sealer from Lowes or HD.
This will be a full shower with toilet and sink.
I'm only running 1 row vertical so they are standing on end and only be at 48".
Blondesense, since I'm only doing 1 row, would I need that leveling system? I would start the first one near the corner and level the edge and butt all the rest up against that one. Maybe start in the middle.
Oh'mike, I will be normal tile on the concrete floor, would I have to use the durock there or have to?
Old 03-23-2013, 06:28 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 224
Sorry, that is not an answer, there is no product by that name. I'm trying to determine how you're gonna do this and with what specific products. Get back with specifics.
It doesn't matter how high you go. The difficulty comes within the area of each tile. The wall need to be very flat. The tiles are likely to not be perfectly flat, that can be a problem. Tiles that large are going to have some degree of warpage.
Jaz
Old 03-26-2013, 12:20 AM   #7
JazMan,
Sorry. I will be placing metal studs every 12"O.C. due to the durock 1/2" only being 3' wide. Attaching the durock to the studs every 8".
I will then coat the durock with "Mapelastic AquaDefense" waterproofing and crack isolation membrane from Lowes that is applied with a roller.
Then apply thinset with polymer additive to the walls and apply the tile.
Old 03-26-2013, 12:39 AM   #8
Tileguy
JazMan's Avatar
Rewards Points: 224
I don't know the size of your shower, but the boards normally go horizontally on the widest wall. But, 12" oc is good.
Be sure to follow the wet-film thickness directions for the Aqua Defense. Usually 2-3 coats.
How about the floor, how are you building the floor? The lower walls, curb and floor are the important part and where 95% of the failures happen when not done right.
Jaz
Old 03-26-2013, 11:08 AM   #9
Bill Kearney
Rewards Points: 1,174
Jaz is right. Be SURE you seal the hell out of the space. Contrary to popular belief tile and backer board are NOT waterproofing elements. Putting up the membrane properly goes a long way toward eliminating problems with leaks, mold and the like. We did our old tub/shower with RedGuard and it worked great. 5 years after the job was done we tore down the house. I tried to separate a bit of of the marble listello tile but the bond of the RedGuard and thinset were tougher than the tile! Our new ones will all be Kerdi membrane, as the tile guy's been very pleased with how it works for him. Either way works, just be sure to follow the manufacturer's instructions to the fullest.
wkearney99 is offline   Reply With Quote
Tags
durock , quarter , tile , wall
SW Cashmere Paint - Peeling off walls at trim... tmcgovern Painting 4 07-19-2012 10:13 AM
What is acceptable tolerance for framing walls? miamicuse Remodeling 24 07-10-2012 08:47 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
