Durabond Thinset - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-22-2013, 12:49 PM   #1
Durabond thinset
Anyone recommend something different or a different brand? I am getting ready to tape the seams between durock and durock, and between durock and greenboard. Does it matter which thinset brand I use? Modified or unmodified?
Jay2013 is offline   Reply With Quote
Old 07-22-2013, 06:51 PM   #2
DIY staff
Rewards Points: 7,174
Modified thinset and tilers mesh for seams and corners---very thin--humps will make your tile rock,causing lippage.
If the Durrock will not be waterproofed---do the mesh and tape as you tile---
For the Durrock to Gypsum board seam--Multipurpose (green lid) is fine---or use the easy sand in the white bag--durrabond would be nice,but not needed---use it if you have it---
JetSwet (07-24-2013)
Old 07-29-2013, 10:17 PM   #3
For the gypsum to durock seam, do I use the green lid compound, along with the alkaline tilers mesh used for the durock to durock seams? Also, how much of the paint/texture should I sand off the gypsum to allow the tilers mesh and green lid compound to stick?
using recently mixed thinset with newly mixed thinset DiyCR fan Flooring 6 03-19-2013 08:19 AM
White thinset and Gray Thinset, does it really make a difference.. yummy mummy Tiling, ceramics, marble 25 02-03-2012 11:00 PM
questions about thinset ponch37300 Flooring 16 03-16-2011 11:45 AM
Fortified Thinset poolecw Flooring 4 10-31-2008 07:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 03:51 PM
