Drywall Meets Hardi Backer - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 09:48 PM   #1
drywall meets hardi backer
I have 1/2 drywall and its touching 1/4inch hardie backer. what kind of tape should i use to join the two? also is it ok to touch the two at different levels?
I have the kerdi membrane which i cover both the drywall and hardi where they meet? any suggestions. I will using stone tiles only on the hardi backer.
get'erdun is offline   Reply With Quote
Old 01-05-2012, 09:55 PM   #2
Rewards Points: 14,312
There was suppost to be 1/2 Hardee Backer on the walls not 1/4".
The floor gets 1/4".
One bumb up againt the wall and there's going to be a hole in the wall.
Now your stuck with have to add another layer of 1/4 or removing what you have and replacing with the right material.
Old 01-05-2012, 10:04 PM   #3
Rewards Points: 582
not sure why you used 1/4" on wall should be 1/2" then problem would go away yes....when we make mistakes we learn so much....
Old 01-05-2012, 10:35 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What the heck are you doing? Is this a shower?
What kind of stone tiles?
Let's see if we can save you some heartache down the road.
XXX
Old 01-08-2012, 08:47 AM   #5
What kind of issues would i run into by having the wall setup this way?
Right under the drywall I have a bullnose that will outline the separation but in a nice way.
One of my concerns were, what kind of mix should I use to join the two?
Should I use the fiba tape that they use on the hardie backer board?
Also I will cover the shower walls(that will get tile) with kerdi membrane so the membrane will touch or over lap onto the drywall(only the edges.
I will post a pic later today so you guys can better guide me.
On the floor I dont have any hardie bakcer because I will have nuheat first then ditra then the tiles. All on top a 3/4inch floor.
The stones are travertine tile.
thank you all for your quick responses. sorry i didnt get to reply sooner. work is very busy.
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
Skylights: New drywall meets popcorn ceiling. How to make look good? 211 Drywall & Plaster 2 01-11-2011 03:07 PM
where tile backer meets drywall rtoni Building & Construction 11 01-07-2011 09:05 AM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 04:34 PM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 10:16 AM
